Metal fatigue
  • gordone
  • gordone's Avatar Topic Author
Metal fatigue
22 Oct 2017 07:05
#773449
When I removed my rear wheel today, I discovered some metal fatigue on the back side of the rear gear, please see attached photos.
I don`t think these is any problem? but I wanted to check with you all.
The metal fatigue is not whole way around, but maybe 1/2 - 2/3 of total.
I have not found cracks going through.
Is it safe to use the part further?
Project:
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Metal fatigue
22 Oct 2017 07:15
#773452
I would change the bearing. All Balls has a kit with all three.
  • gordone
Re: Metal fatigue
22 Oct 2017 07:21
#773453
Thank you, my plan is to replace all three, but I was concern about the metal fatigue, you can see on the ALU its not clear on the surface?
Where do you find the kit with all three? I have used partzilla and order one by one based on part number.
Project:
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • loudhvx
  • loudhvx's Avatar
Re: Metal fatigue
22 Oct 2017 08:35
#773459
If you are talking about what looks like a million tiny cracks on the surface, they all look like that. I think it's from the casting process.
  • gordone
Re: Metal fatigue
22 Oct 2017 09:55
#773464
ahh... good news :) was afraid it was wear and tears..
Thank you.
Project:
  • gordone
Re: Metal fatigue
22 Oct 2017 10:11 - 22 Oct 2017 11:41
#773466
www.partzilla.com/catalog/kawasaki/motor...ke-chain-81-82-h1-h2
1981 KZ650-D4 (The SR series of KZ650 was internally known as the Kawasaki KZ650D.)
European model.
When I look at partzilla I got a wheel with spiders but, I have ALU fix wheel, I`m not sure what you call it in English :)
So my questions, is the part the same when it comes to bearings?
I have also disc brake.
I have compared different models and it`s look likes the bearings is identical on different models around these years?
With or without disc brake etc.. ?
Is there a way can confirm these by using serial number on the wheel or something?
Maybe the best is to measure the dim. on the bearings I have ?
Project:
Last edit: 22 Oct 2017 11:41 by gordone.
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Metal fatigue
24 Oct 2017 14:34
#773661
I think mainly casting defects - but I don't like the look of the micro cracks coming from the sprocket mount holes, a high stress area.
Without x ray or dye testing difficult to assess but I would keep an eye on it - certainly by next tyre change.
I had a really bad crack that opened up on my z1000R hub, and many years ago a rear caliper mount brake on me on the road.
Sometime ago I posted a similar thread on a gpz1100 clutch basket and the general consensus being quite normal.
Not so sure myself.
  • Nessism
  • Nessism's Avatar
  • gordone
Re: Metal fatigue
24 Oct 2017 23:00
#773689
Thank you all for your feedback, now I can sleep in the night :)
Project:
