83' kz760 twin k wheel swap and chain conversion
  • Ltd-18ner
  • Ltd-18ner's Avatar Topic Author
23 Aug 2017 17:12 - 23 Aug 2017 17:19
#769579
*APPARENTLY YOU CANNOT EDIT TOPIC TITLES. MEANT KZ750
I'm the proud new owner of a 83 kz750 k! It's my first kZ, but had. CB before this!
The 83 750 twin k model I have has the stock 16 mag wheel drum brake and 19 mag disc brake set up.
I'd like to have a 18 spoked wheel disc brake in the rear and a 19 disc brake in the front. I understand I'd have to somehow mount the rear master cylinder i went to a disc in the back. I'll also entertain the idea of having an 18 spoked drum brake in the rear too!
What are my options for wheels? Which years and models can I swap with? I see a kz900 rear 18 with drum brake on eBay right now. Would that work? I'm lost on this!
Also...has anyone ever done a belt to chain conversion on my year and model?
Thanks in advanced!
Last edit: 23 Aug 2017 17:19 by Ltd-18ner.
Re: 83' kz760 twin k wheel swap and chain conversion
23 Aug 2017 17:38
#769584
If you switch from drum to disk in the rear you also need to replace or modify the swing arm. The disk setup has the torque link mounted to the top of the swing arm; the drum has it mounted on the bottom. Ed
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
23 Aug 2017 17:46 - 23 Aug 2017 17:48
#769587
For the wheel and drum to disk brake swap, everything is possible with a little work and knowledge. I do it on my project bike.
But have never do a belt/shaft to chain swap.
The main thing is the frame/chain/wheel/rear and front sprocket off set, clearance, alignment, adjustment, if you go to bigger tires and rims as stock.
Last edit: 23 Aug 2017 17:48 by Scirocco.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
23 Aug 2017 18:05
#769591
He can use the bottom torque link,push or pull torque it is the same force effect.
23 Aug 2017 20:35
#769614
Scirocco wrote: He can use the bottom torque link,push or pull torque it is the same force effect.
Not true. I suspect you haven't looked at the swing arm and disk brake setup. (See image below.) There's no way I can see that one could attach a torque link from the disk brake caliper bracket to the bottom of the swing arm without some serious modifications to things. Notice the bracket has the mounting point for the torque link on the right hand side and the torque link runs from that mounting point to the top / forward part of the swing arm. I see no way to run it to the bottom of the swing arm. Even if one was to hang that caliper bracket facing down instead of up the mounting point would then be facing the rear of the bike rather than the front. Ed
  • TexasKZ
  • TexasKZ's Avatar
23 Aug 2017 21:21
#769616
With the stock 16 inch wheel, the belt to chain conversion is very simple. All you need are the sprockets and chain that fit a chain drive 750 twin. A different rear wheel may have a different offset that will complicate things. It can be done, but I seriously doubt there is a simple bolt-on solution.
  • Ltd-18ner
25 Aug 2017 00:26
#769706
Hey guys....great feedback!
Welding on a tab for the Disc Brake isn't too big of a deal for me. I'm ok to make mods to the frame and swing arm to get the disc brake going. I'm more concerned with clearances and bearing sizes and what not.
Does anyone know if I can bolt on a 1000 or 900 rear swingarm onto my 750?
  • martin_csr
  • martin_csr's Avatar
25 Aug 2017 04:23 - 31 Aug 2017 06:26
#769711
From the diagrams at Partzilla the 750K has the same swing arm collar & pivot bolt as the KZ1000P models, so you might be able to use a swing arm from one of those police bikes. I would compare the widths. not sure if the 1000P wheel is wider or whether or not that would be problematic. Also, the 750K has smaller axles than the earlier 750 Twins & 1000s.
If you're thinking of a dual disk front brake, the 750K has the same steering stem (lower triple) as the KZ750H Ltd models, so you can probably use the forks, brakes & Fr wheel from one of those.
Last edit: 31 Aug 2017 06:26 by martin_csr.
  • Ltd-18ner
25 Aug 2017 09:46
#769731
Wow guys, I love this forum already!
Ok...So i found out that the KZ900 and KZ1000 share the same rear axle diameter. And the KZ1000 shares the same axle pivot bolt as my 750k.
This means I can get the swingarm for the KZ1000 and use an 18 rear spoke wheel from a kz900 and bolt that onto my KZ750k.
:silly:
Now to make sure I can do the chain conversion and not have any issues.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
25 Aug 2017 15:23 - 25 Aug 2017 15:29
#769752
Long story short.
This is dependent of swing arm opening width for the rear wheel and the correct spacers to set the wheel in the middle of the frame and equal to the front wheel position. The front and/or rear sprocket have to adjust so that they are in a straight line with the chain. and not hitting the frame or the tire.. This can be done with new or modified spacers and/or offset front sprocket.
You will see what you have to do when the parts come together.
So many possibilities. It is dependent to the parts do you use..
Last edit: 25 Aug 2017 15:29 by Scirocco.
  • Ltd-18ner
26 Aug 2017 00:08
#769774
Yup!
All that is kinda implied. I'm new to KZs but not to building custom bikes. I'm hoping that the swingarm from the kz1000 can be accepted by my 750 frame! Does anyone have the specs on the 1000 swing arm? I'll measure the 750 swingarm tomorrow....
  • Ltd-18ner
28 Aug 2017 08:40
#769916
So it looks like the width of my swim arm where it bolts into the frame is about 9.5 inches? Cant get too good of a measurement...does anyone know what the measurement of the kz1000 swing are is where it bolts to the frame?
