Keys fall out of barrel
- Irish Yobbo
06 May 2017 18:47
Both my KZ's (KZ250 and KZ750) have had the same issue where the key can be removed from the barrel when running. This wasn't really an issue with the 250, but the key just fell out when riding for the 2nd time today. The first time I saw it happen and stopped and picked them up. This time I didn't notice, but fortunately they got stuck under the handebars. But it's a problem just waiting to happen.
Is there any repair that can be done to hold the keys in place, or even just make the barrel a bit 'tighter' so the key doesn't come out so easily? I've tried with a freshly cut key with no success, it's the barrel. And the only thing I have on the keyring are my keys to the garage and house, so no great weight.
I'm considering making some sort of clip to attach it to the handlebars so it can't come off the bike, but is there any other repair except for getting a new barrel?
1981 KZ750 LTD
Re: Keys fall out of barrel
06 May 2017 19:23
No eBay APP ID and/or Cert ID defined in Kunena configurationI finally replaced the switch. I still use a lanyard with them. If the tumblers are worn out, so is the switch. I had a problem with it shutting off while riding. ANOTHER reason to replace the switch.
06 May 2017 19:45 - 06 May 2017 19:49
Sometimes a key lock profile is in so weak shape ( by construction ) that the internal lock of the barrel have not adequate tension ( hold by the springs of the bolt locks )to hold the key in the barrel
Last edit: 06 May 2017 19:49 by Scirocco.
07 May 2017 06:31
Are there a bunch of keys on your motorcycle key chain? You probably need to repair or replace the ignition switch, but in the mean time if the keychain is heavy, try removing all of the other keys & whatnot. If there's only one key, then never mind.
- 9er rider
- Keep a cool tool
07 May 2017 09:29
I replace all the locks so it only takes one key.Z1 parts inc. as far as the gas cap 1 key fits all good luck finding the roll pin!! Z1 E is the only place Ive found them.
- Irish Yobbo
07 May 2017 16:11martin_csr wrote: Are there a bunch of keys on your motorcycle key chain? You probably need to repair or replace the ignition switch, but in the mean time if the keychain is heavy, try removing all of the other keys & whatnot. If there's only one key, then never mind.
There are two more keys on the keyring, but I tried taking them off and it didn't help. The keys hanging down lean onto the handlebar and actually help it stay in.
9er rider wrote: I replace all the locks so it only takes one key.Z1 parts inc. as far as the gas cap 1 key fits all good luck finding the roll pin!! Z1 E is the only place Ive found them.
This sounds like a good option if I can get it for my bike. I'd prefer to keep the same key for everything (my seat lock and helmet lock still work really well though). My tank lock doesn't work anyway, any key will open it.
Does anybody know what parts are interchangeable from model to model? There doesn't seem to be a set sold for an '81 KZ750 LTD
1981 KZ750 LTD
- rstnick
07 May 2017 17:45Irish Yobbo wrote: I'm considering making some sort of clip to attach it to the handlebars so it can't come off the bike, but is there any other repair except for getting a new barrel?
That's not a bad idea.
I have the same problem on my KZ, ignition key will come out.
Have lost one already.
I work on locks for a living, and can't repair the KZ locks. Don't have pinning kits for them.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
