petcock 51023-1002 1976 900b
- Paulharshaw
27 Nov 2016 12:36
So im looking for a replacement petcock for my 76 900 ltd, but all Im finding is part # 51023-048/055. The part # for the ltd is 51023-1002 are these compatible?
- Mcdroid
- Gone Kwackers
Re: petcock 51023-1002 1976 900b
27 Nov 2016 13:45
You should also be searching for petcocks for KZ1000B1-B4 (1977-1980 LTD) as they also use 51023-1002. There is at least one used one on eBay and several aftermarket replacements.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
27 Nov 2016 14:17
- Paulharshaw
27 Nov 2016 19:36
So I checked out what you suggested but the part # is different. 53021-1002 compared to 53021-002? Are they the same
27 Nov 2016 20:59
A pic of what you have will help with suggestions.
- Paulharshaw
28 Nov 2016 03:45
Yes it looks just like the 53021-043 petcock. It's just that the part #s don't match?
28 Nov 2016 05:36
From the diagrams at partzilla the 900A & Ltd use the same mounting nut & packing. Z1Enterprises.com lists several fuel valves for both of the 76 900 models, and they all use a 22mm nut.
As for the difference, is the Ltd tank smaller than the 900A?
maybe the siphon tubes are different. or maybe one valve is shorter than the other. ???
28 Nov 2016 06:32
I've seen them with one nipple coming out the side. Without having them side to side or a pic, advice would be only guessing. The supplier I suggested has a 100% money back guarantee and have treated me right.
The following user(s) said Thank You: Paulharshaw
28 Nov 2016 06:41Paulharshaw wrote: So im looking for a replacement petcock for my 76 900 ltd, but all Im finding is part # 51023-048/055. The part # for the ltd is 51023-1002 are these compatible?
Per Dave Marsden (upper case from original):
...THE [KZ900-B1 LTD] TANK WAS A MUCH SMALLER PEANUT SHAPE AFFAIR.
THE TANK CAP REMAINED THE SAME AS THE Z900-A4 BUT THE FUEL TAP WAS MODIFIED BECAUSE OF THE SLIMMER DESIGN OF THE TANK. THE OUTLET PIPES ON THE NEW TAP WERE ANGLED TO GIVE CLEARANCE FROM THE CARBS...
FUEL TAP: 51023-058
Click here > www.google.com/?gws_rd=ssl#q=51023-058
28 Nov 2016 07:19
That's what I thought. The main fuel tube looks about 2" longer and one nipple is on the side' $22 is cheap and I'd replace the NOS rubber parts. :whistle:
- Paulharshaw
28 Nov 2016 12:01
I'd go with the $22 one and replace the two O rings. Can't beat the price.
