1984 kz700 cafe racer help
  • Nmiller54
  • Nmiller54's Avatar Topic Author
01 Nov 2016 10:28
#746853
I bought a good running 1984 Kawasaki ltd 700 and am trying to build a cafe styled bike. I am just not sure what forks to use or how to get the desired look in the front end thanks
  • Nessism
  • Nessism's Avatar
  • Away
Re: 1984 kz700 cafe racer help
01 Nov 2016 12:34
#746883
The KZ700 is a fine machine. Just remember: Form follows function, not the other way around.
  • martin_csr
  • martin_csr's Avatar
01 Nov 2016 13:36 - 02 Nov 2016 05:51
#746889
Last edit: 02 Nov 2016 05:51 by martin_csr.
The following user(s) said Thank You: Nmiller54
  • Nmiller54
01 Nov 2016 13:55
#746890
Thanks for the quick reply the really important thing to me is to change the rear king and queen seats but I thought I'd ask about the forks thanks can someone give me some tips for the seat
  • Nerdy
  • Nerdy's Avatar
  • Away
01 Nov 2016 14:19
#746892
Nmiller54 wrote: I bought a good running 1984 Kawasaki ltd 700 and am trying to build a cafe styled bike. I am just not sure what forks to use or how to get the desired look in the front end thanks
Welcome aboard!
What is the specific "desired look"? "Cafe racer" can cover a wide range of machines.
And as far as the seat goes, on the simpler end you might be able to get a GPz seat cover and trim the foam to fit. On the more difficult end (heh heh) you have the rather uncomfortable full-on cafe racer seats: basically a fiberglas pan that sits on the frame rails and may have as much as a FULL INCH of padding. :-)
It's your bike, obviously, so it's up to you but have you thought about whether you want to cut the frame? That will greatly influence the end result. No cutting and no welding will limit your cafe-esque options but will allow you to return the bike to stock at some point if you decide to do so.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • Nmiller54
01 Nov 2016 15:45 - 01 Nov 2016 15:46
#746900
Attachment IMG_0380.PNG not found
I hope you can see that picture but this is what I am hoping to get to I am alright with cutting and welding the frame also
Last edit: 01 Nov 2016 15:46 by Nmiller54.
  • Nerdy
  • Nerdy's Avatar
  • Away
02 Nov 2016 14:20 - 02 Nov 2016 14:21
#746986
That's pretty sharp, though this is what I picture when someone says "cafe racer""
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
Last edit: 02 Nov 2016 14:21 by Nerdy.
  • GPzMOD750
  • GPzMOD750's Avatar
02 Nov 2016 15:47
#746993
There was only one KZ700, it was the A1. This was considered a "standard". It was a debored KZ750L3. There wasn't a KZ700 LTD. check the vin number. It should tell you what you have.
How about a pic of the actual bike.
  • TheForumTroll
  • TheForumTroll's Avatar
04 Apr 2017 05:47
#758438
Hey, another 700! Hope you get some pictures. I'll add one of mine, though it is from last year so some stuff like exhaust, mirrors, etc. have changed.
-[ KZ700-A1 '84 ]-
