Front 19" KZ spoke rim best tube or go tubless?
- tomsbadkz
17 Oct 2016 12:34
I'm running a 77 KZ1000 that should do 140mph in the quarter mile. I'm running a 19" spoke wheel. Is there a certain tube to use that will be safer and can spoke rims be set up to run tubeless? Didn't know if a tire will seal on a spoke rim because the bead might not seal even if the spokes are sealed. HELP!!!! Tom
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- JoHNY
Re: Front 19" KZ spoke rim best tube or go tubless?
17 Oct 2016 12:46
I guess it depends on the age of the rim. I had a lovely rim made for me by Buchanans for my now sold Sportster and that was tubeless. Pretty sure if it's leaky you can source some kind of sealant or something similar
www.buchananspokes.com/
Kawasaki Z750P7 Spectre, Triumph Daytona 955i, Honda CBR1000FN
17 Oct 2016 13:29
Run a tube in a V rated tire.
- tomsbadkz
17 Oct 2016 14:12
Yea, I'm running a V rated Avon tire. I read some other areas about tube thickness and heat being a factor for HD tubes, but it's also nice to keep the weight down but safely.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- missionkz
17 Oct 2016 19:55with respect to heat.... uummm ...you are only running over 100mph for a few seconds so I seriously doubt a good inner tube in a V tire is going to overheat and destruct.tomsbadkz wrote: I'm running a 77 KZ1000 that should do 140mph in the quarter mile. I'm running a 19" spoke wheel. Is there a certain tube to use that will be safer and can spoke rims be set up to run tubeless? Didn't know if a tire will seal on a spoke rim because the bead might not seal even if the spokes are sealed. HELP!!!! Tom
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- tomsbadkz
18 Oct 2016 06:10
It's gonna be a street bike, :lol: I'm gonna ride this on the weekends for cruising also.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- MDZ1rider
18 Oct 2016 09:01 - 18 Oct 2016 09:01
Getting spokes to seal for a tubeless application can be done, but requires basically rebuilding the wheel with sealant on each spoke. Most guys who have tried it complain of constant leaks and maintenance. There is a product to run tubeless tire on spooked rims for dirtbikes. Check out Nuetech TUbliss (
nuetech.com/tubliss
). It may be worth giving them a call.
Last edit: 18 Oct 2016 09:01 by MDZ1rider. Reason: correcting link
