Non kz engine swaps
  • 80B4
  • 80B4's Avatar
Re: Non kz engine swaps
08 Sep 2016 21:16
#741648
Ed, that's a Yamaha FJ.1100 or 1200.motor in that frame, not a Suzuki motor.
1980B4 1000
1978 Z1R
1978 B3 750
09 Sep 2016 05:19
#741669
80B4 wrote: Ed, that's a Yamaha FJ.1100 or 1200.motor in that frame, not a Suzuki motor.
Thanks! I made the correction. Ed
09 Sep 2016 05:33
#741670
Stuffing in a larger engine may require that the engine be removed in order to check and/or adjust the valve clearances, as there may be insufficient room to remove the valve cover when the engine is installed.
Good Fortune! :)
  • jowek70
  • jowek70's Avatar Topic Author
09 Sep 2016 06:02
#741676
Thanks for the comments guys
Valve adjustments on new bikes is like 15k increments
Not very concerning to me
Guess I might be pioneering this whole thing ha
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
09 Sep 2016 08:29
#741687
jowek70 wrote: Valve adjustments on new bikes is like 15k increments
Not planning on it lasting that long? :whistle:
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • jowek70
09 Sep 2016 08:36
#741688
No I live in Wisconsin so 15k could be 2 seasons of riding
I'm very good to my bikes
Ito me having a bad ass daily rider would be worth pulling the engine every winter to adjust valves
  • Julian_Boolean
  • Julian_Boolean's Avatar
Re: Re:Non kz engine swaps
09 Sep 2016 13:33
#741720
What about a ZZR1100 engine, water cooled GPZ and ZRX are the same engine.
  • kz n az
  • kz n az's Avatar
09 Sep 2016 21:15
#741754
Im putting a 750 gsxr in a 77 650 frame with 03-04 636 suspension
front and rear. Still under construction, but Im sure this has been done before.
The build so far has been pretty ez.
  • jowek70
10 Sep 2016 08:18
#741770
kz n az wrote: Im putting a 750 gsxr in a 77 650 frame with 03-04 636 suspension
How's it fit in the frame?
New liter bike engines are tiny so I'm guessing I'll have to ad flanges to the frame to mount it properly
Do you have a built thread I can view?
  • kz n az
  • kz n az's Avatar
10 Sep 2016 22:11
#741815
No Im sorry I dont have a thread because I suck badly on computers.
The Suzuki top and bottom rear motor mounts are a perfect fit to the
77 kz frame. All I did was slide the motor to line-up with the rear sprocket
which put motor off center of the frame by 1/8 and added new spacer
to the motor mount bolts. Install a new mount on bottom rail to fit suzukis motor. You wont need to notch the frame or an off
set frt sprocket. The exhaust ports will clear the front frame tubes.
The Suzuki headers have a tighter radius so the cut them just before
the bend and added 1 1/2 so the pipes would clear the frame.
The 636 swing arm and frt forks really adds a nice look to the bike.
Hope this helps in some way. If others have a comment please jump in I can use
the help.
GOOD LUCK
  • jowek70
11 Sep 2016 04:55
#741820
kz n az wrote: No Im sorry I dont have a thread because I suck badly on computers.
the help.
GOOD LUCK
Good to hear
Any issues with fitting the throttle bodies?
  • kz n az
  • kz n az's Avatar
11 Sep 2016 05:35
#741822
I must have missed that parts of the conversation my gixxer
has carbs. sorry
