My Calipers are laying eggs? What are these?
- thekelzer
18 Aug 2016 13:41
I've got one for you....
My ZRX and ONLY my ZRX caliper (seals) are repeatedly being eaten (I think?) by something when the bike is parked in it's shed (along with 5 other bikes that have never had the same issue).
Anyone know what this is? Are these the eggs ? They eat so much of the seals that they start leaking, I've replaced them all once already and now they are back! Those 6 pot Tokiko seals are VERY expensive and only available from Kawi for some reason !
Any Ideas?
Mahalo,
KK
Any Ideas?
Mahalo,
KK
1979 CBX1000, 2000 ZRX1100, 1974 Yam DT250A, 1975 CR125 Elsinore, Road King, KTM 250 XC-W, 2008 GasGas 280TXT PRO trials.....oh, and a 400cc scooter to get me to the beach!
Re: My Calipers are laying eggs? What are these?
18 Aug 2016 14:03
That's freaky. I have no idea.
18 Aug 2016 14:19
Spider eggs or calcium deposits?
18 Aug 2016 14:24
Looks like corrosion being released out of pores in the aluminum casting. Did you use some sort of chemical to clean the caliper bodies? I'm not sure what to suggest other than cleaning the bodies in some sort of aluminum safe cleaner (not Simple Green or similar). A ultrasonic tank would be ideal.
- mark in Portugal
18 Aug 2016 15:05
Have you flushed and changed the brake fluid?
You say the seals are being eaten but the picture is of the outside of the caliper; what do the insides of the bores look like?
18 Aug 2016 16:51
Being at the beach can do all kinds of things to metal.
- thekelzer
18 Aug 2016 18:37
No, it's not oxidation...they "POP" if you squish them.....
Must be the ancient Hawaiian brake beetle.....
It's just so weird that it ONLY happens to the ZRX.
Pistons are fine.
Aloha,
KK
Pistons are fine.
Aloha,
KK
- SmokyOwl
18 Aug 2016 19:31 - 18 Aug 2016 20:00
Might be if you're parking the bike in the shed in the same spot, the organism associated with this lives nearby and likes the heat of the calipers for laying eggs. I haven't a clue what it is, I didn't study biology. Try brake cleaner to spray 'em off or are they stuck?
I can't find any animals that spray their eggs though.
1982 Kawasaki KZ1100 A2, Shaft
Never trade the thrill of living for the safety of existance.
Last edit: 18 Aug 2016 20:00 by SmokyOwl.
- loudhvx
18 Aug 2016 19:43
I get that sometimes during a really damp winter. I think it's a chemical reaction between the pitted aluminum and brake fluid and moisture (like Ed said). It usually washes off. If the fluid is washed off and stays off, and/or if the thing stays dry, it usually won't come back.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
