1980 kz1000 front brake clatter.
  • MadShad
  • MadShad's Avatar Topic Author
15 Aug 2016 08:49
#738745
Ok so I've been on a hunt to track down some shakes and rattles that were driving me crazy.
I had a buzzy tach, some rattles in the dash over bumps etc that I was able to get sorted out.
My final rattle I like to take care of is in the front brakes, at low speeds I get a steady clatter that will go away the second I touch the front brakes.
Sounds like 2 spoons being clacked together.
The front wheel is secure, the caliper bolts are secure, the brakes work fine.
The rotors look to be in good shape, I've cleaned and greased the slides and put some lube on the back of the pads.
What am I missing?
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
  • MDZ1rider
  • MDZ1rider's Avatar
Re: 1980 kz1000 front brake clatter.
15 Aug 2016 09:31
#738748
I'm taking a shot in the dark here, but there's a Phillips head screw that goes into the back of the inner pad thru the spacer insert. It could be loose or missing. I just looked at your parts diagram and it is not shown. I know my 80 Z1R has them, and it's not shown on that parts diagram either.
  • SWest
  • SWest's Avatar
  • 10 22 2014
15 Aug 2016 09:53
#738751
Mine were doing that too. There are six O rings on the bolts that hold the calipers together. Mine were wasted or gone all together. I got some at the HDWR store and no rattles.Used a little grease on them so they would slide in and not get pinched. B)
  • MadShad
15 Aug 2016 10:01
#738752
That just might be it.
I'll take a look tonight, should have the orings on the shelf, I have several kits.
  • SWest
  • SWest's Avatar
  • 10 22 2014
15 Aug 2016 10:04
#738753
Three on each bolt. 12 for my duel disks. :lol:
  • MadShad
15 Aug 2016 10:07
#738754
Well, I'll be at least 2 short.
Per the rules of my garage. :woohoo:
  • SWest
  • SWest's Avatar
  • 10 22 2014
15 Aug 2016 11:16
#738764
I put in what I had then got some more. Easy to do. With just a couple the noise went away.
