changing handlebars to taller ones on a 98 KZ1000P
- JefftheBarberKZ1000
27 Jul 2016 12:17
I would like to find out if I could use LTD or CSR model clutch/throttle and front brake cyl CABLES on my 98 KZ1000P for my new larger handlebars?
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: changing handlebars to taller ones on a 98 KZ1000P
27 Jul 2016 12:38
That would depend on how much higher bars you're talking about are we talking ape hangers or what ?
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- mslevin
27 Jul 2016 12:44
The KZP bars are already quite tall. If your new bars are much taller you may have to get longer cables.
1994 Kawasaki KZ1000P
27 Jul 2016 13:17
I had taller bars thinking they would help my back. They didn't, they just made it worse.
28 Jul 2016 16:01
Actually Nothing Apey, approx 3 to 4 inches.. With the current cables I would work but Ive had difficulty finding
actual official lengths and knew the KZ/LTD/CSR were all made certain years and the LTD/CSR were more cruzer style and the Kz had more crotchrocket style. I know the cable lengths of the LTD/CSR are adequate I uncertain of connectability to my 98 KZ. Were I live the only dealers/reps dont seem to be able to determine any of these . Any light on this ridiculous situation would muchly be recieved. Also Ive looked into having these made and ulike harleys etc where this is easy and rougly about a hundred bucks for instock cable extensions its 300+ and its a mail order deal.. Thanks for the reply and keep it upright!
JefftheBarberKZ1000
JefftheBarberKZ1000
28 Jul 2016 16:17
Try calling Z1E.
28 Jul 2016 16:39
Z1E?? Forgive me but I have no Idea about what that is or how to find their contact number
28 Jul 2016 16:42
The following user(s) said Thank You: JefftheBarberKZ1000
29 Jul 2016 05:52 - 29 Jul 2016 05:55
Z1Enterprises lists the cable length & slack for many of their cables, so you could take a gander at the various listings to see whether or not something will work. Doing it yourself might save some time. If you call, they'll probably do the same thing, just look at the measurements they have listed.
PS: I would install the bars & figure out the needed length, then get the appropriate cables. oem cables are preferable, but Motion Pro & Barnet make custom cables.
Last edit: 29 Jul 2016 05:55 by martin_csr.
- Nerdy
10 Aug 2016 14:09 - 10 Aug 2016 14:10martin_csr wrote: PS: I would install the bars & figure out the needed length, then get the appropriate cables. oem cables are preferable, but Motion Pro & Barnet make custom cables.
A single strand of solid core electrical wire will make it easy to determine the appropriate length. You can route the wire the way you would route the cable: it will hold its shape and you can experiment with slack. Once you're done, pull the wire off and measure it.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Last edit: 10 Aug 2016 14:10 by Nerdy.
