1982 gpz 750 clutch cable routing, need help!
  • rinferno
  • rinferno's Avatar Topic Author
30 Jun 2016 18:49
#733415
I need to know the correct way to route clutch cable. I have it coming up left frame rail between 1 and 2 cylinders, up to oil cooler, then under triple clamp, then up to clutch lever, is that correct. It gets tight sometimes doesn't completely disengages clutch. Any help would be appreciated.
1982 gpz 750
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1982 gpz 750 clutch cable routing, need help!
30 Jun 2016 19:08
#733418
Pic. It should run between 1/2, the in front of the lower triple tree, behind the headlight and to the perch.
The following user(s) said Thank You: rinferno
  • Nessism
  • Nessism's Avatar
  • Away
30 Jun 2016 19:08
#733419
Have you ever lubed the cable and helix?
  • rinferno
30 Jun 2016 19:33 - 30 Jun 2016 19:33
#733425
Both lubed, cable routing is the issue, will reroute as per steve.
1982 gpz 750
Last edit: 30 Jun 2016 19:33 by rinferno.
