1981 KZ 750 LTD rear brake retaining clip?
  • 1981kz750ltd
  • 1981kz750ltd's Avatar Topic Author
15 Jun 2016 08:58
#731499
Looking for a source for the rear brake pad retaining clip for my son's 1981 KZ 750 LTD. The brake pads are easily located but finding this magic clip seems to be a trick. Anyone have a source or a picture of this item? Attached is a pic of the caliper and bracket. To add spice to the situation I am trying to handle this long distance as he is in another state.
Attachment Resized_20160615_093046(1).jpg not found
Thanks
  • Nessism
  • Nessism's Avatar
Re: 1981 KZ 750 LTD rear brake retaining clip?
15 Jun 2016 10:08
#731509
That part is still available from Kawasaki. Order from a local dealership or any of the multitude of online dealership sources.
  • 1981kz750ltd
15 Jun 2016 10:18
#731510
I did contact a dealer who was either unwilling to help or ignorant of what to do with older bike parts. In any case they were unhelpful. In many instances I have found it necessary to do their work for them first by coming in with the part number or a picture in order to walk them thru it. Right now I am looking for an aftermarket supplier but if someone has the correct factory part # that will help the dealer parts man/woman order it. ( Parts counter people aint what they used to be) Thanks.
  • Nessism
  • Nessism's Avatar
15 Jun 2016 10:21 - 15 Jun 2016 10:21
#731513
Like I said, look up the parts numbers using one of the multitude of online dealership sources. www.partzilla.com/parts/search/Kawasaki/...780+H1%29/parts.html
Last edit: 15 Jun 2016 10:21 by Nessism.
The following user(s) said Thank You: 1981kz750ltd
  • TexasKZ
  • TexasKZ's Avatar
15 Jun 2016 13:14
#731534
You can also get Kawasaki part numbers and exploded views from Kawasaki.
www.kawasaki.com/Parts
  • SWest
  • SWest's Avatar
  • 10 22 2014
15 Jun 2016 13:26
#731537
If it's not on the computer and current, they're lost. Microfiche? What's that? :huh:
  • 1981kz750ltd
15 Jun 2016 14:57
#731548
Part number found and part ordered. Thank you to all who replied. Ride safe and keep the rubber side down.
