1981 KZ1000 LTD Swingarm Swap
  • iwish4a69camaro
  • iwish4a69camaro's Avatar Topic Author
12 May 2016 17:13
#726032
Guys-
I'm working on my 1981 KZ LTD. my goal is to end up with an AMA style tribute bike to the early days of The KZ being the first Jap bike to win the AMA here in America.
Think Reg Pridmore
The goal is to use mostly period correct race style mods only. I'll retain factory brakes, factory forks, etc. while not stock but try to use period correct modifications, or modifications that appear as period correct.
It seems all those early AMA guys did different things for swing arms. It looks like the original Vetter bike ran some kind of aluminum swingarm. Eddie Lawson's bikes seem to run some kind of braced factory style swingarm that winds up looking like a ZRX arm.
So to the question. What kind of swap or modification would be semi-correct and be a fairly straight forward swap. I want to retain dual shocks and the factory cast 18" wheel. So I guess a 20mm axle. I've seen this done with GS1100E arms as well as ZRX arms.
I'm on a budget. I can source spacers or turned axles if I need them. Not afraid to weld steel or aluminum.
Any advice or suggestions would be super helpful.
  • TexasKZ
  • TexasKZ's Avatar
Re: 1981 KZ1000 LTD Swingarm Swap
12 May 2016 17:16
#726034
You could just add bracing to the stock arm and call it done.
12 May 2016 17:23
#726037
Pic of #21 arm.......
Attachment 00003f-2-3-4-5-6-7-8.jpg not found
  • iwish4a69camaro
12 May 2016 17:38
#726040
650ed wrote: Pic of #21 arm.......
To my eye this almost identical to a ZRX arm.
  • iwish4a69camaro
12 May 2016 17:39
#726041
TexasKZ wrote: You could just add bracing to the stock arm and call it done.
Anyone have details on how the factory originals were braced?
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
13 May 2016 07:22 - 13 May 2016 07:30
#726121
black beauty
moriwaki
Last edit: 13 May 2016 07:30 by 531blackbanshee.
  • 531blackbanshee
  • Vendor
  • Vendor
13 May 2016 07:36
#726123
one somone else done
and another
  • 531blackbanshee
  • Vendor
  • Vendor
13 May 2016 07:38
#726125
rstnick and dcotorot both have stock underbraced arms as well.
it's pretty open to interpretation.
shows us what you decide.
  • SWest
  • SWest's Avatar
  • 10 22 2014
13 May 2016 07:40
#726127
Fine work Leon.
  • iwish4a69camaro
13 May 2016 08:03
#726133
Wow thanks,
Those pics were ultra helpful. I really appreciate it. I'll be posting the process here in my build thread.
I'm a little worried about it warping as I TIG it. I guess I'll V-Block the hell out of it and weld small patches at a time.
  • 531blackbanshee
  • Vendor
  • Vendor
16 May 2016 07:07
#726743
they always tweak around a lil .
i tweak em back until they are square.
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 May 2016 07:21
#726745
Don't you have to deal with the metal's memory?
