Swingarm swap
  • Tirefire Pat
  • Tirefire Pat's Avatar Topic Author
  • (2) 1980 kz1000 b-ltd,,h2-750 triple,sold.kz 550 ,
Swingarm swap
03 May 2016 14:30
#724328
Hey guys how much modification would it take to swap a gs swingarm on to my 80 Ltd 1000 b???? Be specific ..I'm learning as we speak..lol
  • wrenchmonkey
  • wrenchmonkey's Avatar
Re: Swingarm swap
03 May 2016 16:58 - 03 May 2016 16:59
#724371
Hey! Imagine meeting you here! :laugh:
There's been quite a few guys here that have done this kind of mod. Both front and rear actually.
Here's a quick link about a GS1100 swap-in on a KZ.
[ GS1100 Swingarm Swap ]
Should make you feel a bit easier ;)
Last edit: 03 May 2016 16:59 by wrenchmonkey.
The following user(s) said Thank You: Tirefire Pat
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
Re: Swingarm swap
03 May 2016 17:45
#724385
Tirefire Pat wrote: Hey guys how much modification would it take to swap a gs swingarm on to my 80 Ltd 1000 b???? Be specific ..I'm learning as we speak..lol
Depends on which GS...the 750/1100 aluminum arm from 80-83 is a straight - in swap at the front, as far as I can remember. Can't remember what it needed at the wheel end, though. I had to machine frame spacers for putting one of those in a CBX (Honda frame is wider), but remember seeing many KZ's with that arm in them back in the mid - 80's. That doesn't buy you much more tire clearance, though....about the same as a GPz900R swing arm (the original Ninja 900). I think max tire would be a 160, maybe a 170 if you are lucky. 170 is about as wide as you can go without the 630 chain touching the frame near the front sprocket anyway. You should / need to use an offset sprocket set up at both ends for anything wider than 150.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Swingarm swap
03 May 2016 20:43
#724434
It's to stiffen up the rear end. Direct swap. I was watching one and mentioned to one of our members. It sold. It didn't matter, I was doing my own. If one of us got it, I'm glad. B)
