Z1/KZ 900 wheel
Z1/KZ 900 wheel
25 Apr 2016 15:43
I was asked what front wheel I had on my Z1. While I was working at a motorcycle salvage business wrenching, making bikes for sale in the 80's I found 2 4 bolt KZ rotors and 2 H2 calipers. I had a complete KZ 900 wheel so it was a bolt on mod. Had everything I needed including a master cylinder. I got screwed by the owner for my money but got a lot of parts I needed for free. He always wanted my Z1 and after I left he tried to keep a KZ 1000 by writing on the engine "NO PARTS INSIDE," It was a bike I was to work on but I quit before I got it running. It belonged to a cop. Not only did he not keep it, he lost his business too. A year later I rode by to see the building was torn down and a used car lot was on the slab.
The Z1/KZ 900/1000's had a chrome cover on one side hiding the bolt patterns. They had the mounts on the fork legs as well.
- PLUMMEN
Re: Z1/KZ 900 wheel
25 Apr 2016 19:53
Kz650/750 also used that 4 bolt hub.
Re: Z1/KZ 900 wheel
25 Apr 2016 20:14
Is the width the same?
- PLUMMEN
Re: Z1/KZ 900 wheel
25 Apr 2016 23:05
yep,kind of the sbc of hubs there! :laugh:
- I_Tig_in_piece
Re: Z1/KZ 900 wheel
26 Apr 2016 08:30
I like this info! Now I know what to look for with distinct features, hope I won't have to do too much experimenting since I'm using 440 forks, rotors and I believe a CSR right hand caliper. It's a exact mirror to my left side cal. The hunt begins.. :woohoo:
Cheap labor isn't skilled, skilled labor isn't cheap.
1980 KZ440a. I went green.
If you yourself are building an older bike and can see it through till you're riding it, that's proof you have patience.
Re: Z1/KZ 900 wheel
26 Apr 2016 08:36
Why not a early 650 front end?
- I_Tig_in_piece
Re: Z1/KZ 900 wheel
26 Apr 2016 10:07swest wrote: Why not a early 650 front end?
Ummm..idk? Well actually cause that means I'd have to get another set of forks, triple, rebuild kit for said forks for piece of mind and new bearings. The ABs races don't look too easy to remove? Hahahaha! If the 650 were 33mm, I'd totally consider it.
