KZ400/440 Fork Swap Pinch Bolt Question
  • Fiddles
  • Fiddles's Avatar Topic Author
09 Apr 2016 20:53
#720131
I am following the awesome guide of DoctoRot www.kzrider.com/forum/5-chassis/597812-k...r-fork-swap-tutorial
Whats up with the absence of pinch bolts on the 440 forks. I just ordered a set that are also flush, no pinch bolts.
Anyone have any experience with this? All I could find was how the pinch bolts on the front axle/forks are used for alignment.
1978 KZ400 B1 Frankenstein
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: KZ400/440 Fork Swap Pinch Bolt Question
09 Apr 2016 21:00
#720134
What? Pics? :huh:
  • Fiddles
09 Apr 2016 22:16
#720141
That fastening system I see is common on most KZs except that 440 model. Not sure if its significant, will try to find the manual for the 440.
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 Apr 2016 08:21
#720178
I thought you were talking about the trees. The Z1's had one clamp but if yours works then what's the problem?
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 Apr 2016 08:23
#720179
That's wrong they had two clamps but one side the axle screwed into the axle boss, the other side didn't.
  • Fiddles
10 Apr 2016 09:38
#720190
No problem, I'm looking forward to getting rid of the 78 kz400 caliper. I am just curious about those pinch bolts, its seems there are a number of different front axles:
Solid front forks without pinch bolts with an axle and nut (KZ440 LTD)
Front forks with two pinch bolts and an axle and nut
And even a front fork with a threaded side and a pinch bolt side apparently
What are they for? Are they supposed to push the axle up against the top? Modern forks look to have only one pinch bolt in a wrap around style.
I honestly like the idea of less bolts to tighten with the kz440 ltd forks, but wonder if I am loosing anything in alignment? I guess my collars are going to have to be cut like little champions.
