What is size of rear wheel bearings? 80 KZ1000E sh
  • car5car
  • car5car's Avatar Topic Author
  • Banned
  • Banned
08 Mar 2016 21:47
#714580
There is a bearing store pretty close from me, they are cheap.
96 Yamaha Royal Star
82 Yamaha Virago 920
  • martin_csr
  • martin_csr's Avatar
Re: What is size of rear wheel bearings? 80 KZ1000E sh
09 Mar 2016 05:04 - 09 Mar 2016 14:41
#714587
The parts diagrams at Kawasaki.com or Partzilla will have the bearing sizes.
chain drive models have 1 large & 2 smaller bearings at the rear wheel, but instead of the large one, the shaft drive models have a needle bearing at the final drive --- you'll need to reference the manual about it.
there are oil seals you'd probably want to replace. All-Balls bearing kits have the seals. I
Last edit: 09 Mar 2016 14:41 by martin_csr.
The following user(s) said Thank You: car5car
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Mar 2016 06:58
#714600
Unless you need just one, get the "kit".
  • Nessism
  • Nessism's Avatar
09 Mar 2016 07:08
#714602
All Ball's bearing kits come with everything you need and cost less than purchasing the bearings separate. They also come with the appropriate type of grease. Downside is they are generic Chinese bearings. Most bearing failures are related to the grease drying out or water entry anyway so no worry.
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Mar 2016 07:31
#714608
All Ball kits are CHINESE? :ohmy: I guess I'll have to rekindle my relationship with my Kaman bearing guy. I don't want Bossie to suffer the same fate as the helicopter falling out of the air syndrome due to inferior bearings. :whistle:
  • car5car
  • Banned
  • Banned
09 Mar 2016 10:18
#714626
I paid $25 for rear bearing kit. Bearing are from $2 and up shipped from ebay.
Seals are not very important because bearings are sealed.
  • car5car
  • Banned
  • Banned
10 Mar 2016 16:37 - 10 Mar 2016 16:45
#714786
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
