Installing Rear Wheel
- Bowman
06 Mar 2016 14:48
Finally getting warm enough here to start putting my old 750 twin back together.
My FSM talks about getting the chain set up correctly using the chain adjusters and that's all straightforward, I've adjusted chains before. Then it says "tighten the caliper holder sleeve nut securely." . It's a 36mm nut and I don't have a wrench even close to that big. Would "securely" mean basically as snug as you can get it with a crescent wrench?
Honda 55 Trail don't ask me what year, 65? (sold)
79 Yamaha XS400 (sold)
76 KZ750B Twin (project)
72 Honda CT70 (project)
Re: Installing Rear Wheel
06 Mar 2016 15:15
Yes. Axle nut?
- Bowman
06 Mar 2016 15:23
Axel nut I can deal with, it's only 27mm and FSM says torque it to 72-101 ft/lbs.
- StreetfighterKz
06 Mar 2016 16:44
My guess is the "caliper holder sleeve nut" is the bolt that secures the brake stay tomthe caliper/caliper bracket. By loosening it you are able to adjust the axle more freely.
Later. Doug
Later. Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
