New bike, what's up with this seat?
Re: New bike, what's up with this seat?
02 Mar 2016 16:04
Damn that thing is pristine.
- Jonny
- woot!
02 Mar 2016 16:28 - 02 Mar 2016 16:31
Pop Rivets!! Sir, I am sure your not suggesting I would ever pop rivet anything to my beloved Lila. This is not a Honda after all! :ohmy:
They are actually SS allen bolts. I replaced pretty much all the original hex head stuff since many were looking a bit grubby and it was going to be too much work for me to strip them all, and get an electroplating kit.
It is, in fact stock, and the rear fender is curved to match the bend in the mounting bracket. The photo isn't great, but you can see they mate pretty much exactly. Again, if this had been modified,and why would anyone bother, it would have been one hell of a lot of work to maybe just change the angle of the ducktail slightly. I can't rule it out entirely, but I can't imagine anyone bothering. If I were to straighen the mounting plate, then I would have to beat hell out of the much thicker fender mounting point as well.
Lastly, an idea of how the everything kind of lines up. I think we're on to something here, Ed. The frames are subtly different, but not much. And I too had always though everything pre-77/78 was the same except forthe charging etc....
Sorry if this is high-jacking a little. I've just been trying to figure out this seat thing for a long time now, and this is a good lead.
'78 KZ 650C2 'Lila'
'71 Norton Commando 750 'Eadie'
St. Catharines, ON (Mostly, anyway...)
Last edit: 02 Mar 2016 16:31 by Jonny.
02 Mar 2016 16:33
Sorry about the pop rivet comment. Looked like a bad job in the pic. That bend looks suspect and the seat being hammered down. PO's have a tendency to do things like this. :whistle:
- datachomper
02 Mar 2016 18:14
The following user(s) said Thank You: Jonny
- datachomper
02 Mar 2016 18:20
I was hoping maybe somebody could double check these measurements against their stock seat so I can get a rough idea if this seat pan can be used with a stock foam/cover kit.
Under rear lip to major bend
Major bend to latch
Major bend to latch
- rstnick
03 Mar 2016 14:41 - 03 Mar 2016 14:43
I've got both a C1 and C2s, and the seat swaps between no problem.
The rear frame section is the same.
I've got a stock seat downstairs I can measure shortly....
Johnny, the curved part of the brace should be flat.
Theses pictures showing spike stips during the seat recover.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 03 Mar 2016 14:43 by rstnick.
- rstnick
03 Mar 2016 15:04
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- Jonny
- woot!
03 Mar 2016 16:39
Thanks Rob,
Occam's razor at work. The brace is bent. Interesting tho, how everything is so perfectly and evenly bent and matched. Thanks for getting the measurements up. Once I can get to my spare parts, I can compare what I have as well, and play with what I have to make it fit. I'd rather not have to hammer in another seat pan to make it all fit! :woohoo: Thanks as well datachomper, your gonna love that '650 I bet.
Cheers!
Jon
Cheers!
Jon
'78 KZ 650C2 'Lila'
