Rear Brake lockup
- JENKFITLIFE02
- No Regrets
Rear Brake lockup
17 Feb 2016 12:46So I took my new bike out for a little yesterday and noticed when shifting the back brake was locking up in low gear. The rear brake pedal is super super tight with no give. I put it in neutral to put it away and still locked up. I turned it off and on and it loosened. I dont know whats going on as the sprockets and pads as well as rear tire are new. I am going to the mechanic saturday I hope its nothing nuts...he said sounds like a quick adjustment.
Re: Rear Brake lockup
17 Feb 2016 12:53
Do you have a manual? If not get one.
- JENKFITLIFE02
- No Regrets
17 Feb 2016 13:04
Yea I have a clymer manual but I dont wanna mess w the brakes I found a good local mechanic to look at it this weekend.
- PLUMMEN
17 Feb 2016 13:19
Pull the brake pedal off then clean/lube the pivot to see if it helps.
- jdvorchak
18 Feb 2016 07:29
You don't mention the year or model. Disk brakes or drum on the rear?
If disk:
If you loosen the rear bleeder screw and the brakes free up then the return or "spooge" hole in the Master Cylinder is plugged. There are at least two ways to clean that hole, which is very very tiny. The first method I use is the easy cheap way. Remove the caliper, leaving all lines etc hooked up, from the mount. Pull the brake pads out. Use a large C clamp to try to compress the piston back into the caliper body. It should move smoothly with just normal hydraulic pressure. If the spooge hole is plugged, you will be met with a lot of resistance compressing the piston. If so try harder pressure. It also helps to pump the brake pedal a few times to expand the piston, then push it back in with the C clamp. Do that a few times until the piston compresses smoothly.
The other method, or ,more proper way, is to remove the MC, take it apart and clean it using a #80 drill bit or a #10 guitar string to clean the two holes in the MC between the pump and reservoir.
If disk:
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
John
83 KZ550M1
83 KZ1100LTD
Also own:
- KZB2 650
18 Feb 2016 08:02
If its a drum Martin on here has said his glue gave way and the pad came off and jammed up...... might replace mine the next time I remove the wheel..... and check and see if the petal return spring is on there and working.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- JENKFITLIFE02
- No Regrets
18 Feb 2016 08:13
The back tire, brake pads, chain, and sprocket were just put on a month ago i have all the sales receipts and what not. Its ride able just when i slow to a stop it jams up. That all sounds too technical for me lol Im gonna let a pro fix it. Its a 1980 KZ750e
18 Feb 2016 08:23
Learning to work on a 30 year old bike is a MUST. Besides, it's a good feeling knowing what you have between your legs.
The following user(s) said Thank You: KZB2 650, PLUMMEN
- Rave71
19 Feb 2016 06:40
I had this same issue, whenever I stepped on the brakes I would have to lift the pedal back up with my toe and it continued to get worse. I needed new pads anyway and I figured a bleed couldn't hurt so I assumed the worst and purchased the master cylinder rebuild kit and prepared myself for a days worth of work. As soon as I disconncected the the pedal and bracket and removed it I expected it to pivot freely but it was locked in place! I "gently" beat the pedal out of the bracket, cleaned it all up and applied a good coat of never seize to the pivot point. Threw it all back together and it worked like a charm, took about an hour and required nothing but a wire brush, rubber mallet and the never seize.
1981 Kz750 ltd
Hudson Valley NY
USMC/OIF Vet
Hudson Valley NY
USMC/OIF Vet
- JENKFITLIFE02
- No Regrets
19 Feb 2016 07:22
Thats awesome what a relief I bet. I dont feel comfortable doing all that I have an appt with a local older mechanic he deals with older bikes and is only $40 an hour. He told me it would be less than hour so it should be cool by tomm afternoon. Finally gonna be 58 degrees thats a riding day!
- JENKFITLIFE02
- No Regrets
22 Feb 2016 06:35
Got the bike looked at, oil had gunked up in the pedal making it impossible to move. Just a quick clean up and its like new. Tightened a few things and adjusted my carbs bike is perfect!
- Rave71
22 Feb 2016 08:28
Awesome quick fix... Sounds like we had the same problem after all. Happy riding!
1981 Kz750 ltd
Hudson Valley NY
USMC/OIF Vet
Hudson Valley NY
USMC/OIF Vet
