aftermarket shock installation
  • razmo99
  • razmo99's Avatar Topic Author
09 Dec 2015 16:27
#702578
No eBay APP ID and/or Cert ID defined in Kunena configurationHi i got some shocks of ebay that have a cans hanging off them
exactly like these > (just a lot cheaper)
I have installed them with the canister facing towards the front wheel does this matter or should they be facing towards the back fot he bike?
- Z500 B4
-GPZ900R A9-10 ish
  • Nessism
  • Nessism's Avatar
  • Away
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
Re: aftermarket shock installation
10 Dec 2015 01:36
#702597
Doesn't matter as far as performance is concerned but they might look a little odd mounted that way.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • razmo99
10 Dec 2015 10:43
#702639
Well it was that or removing the helmet hook on the right side.
I must admit these shocks tho are really stiff compared to my previous ones which I think were the originals.
I have the spring preload set to the lowest it will go, how much affect does the pressure in the canister effect ride quality and whats a good starting setting do you reckon?
- Z500 B4
-GPZ900R A9-10 ish
  • ThatGPzGuy
11 Dec 2015 13:20
#702739
razmo99 wrote: Well it was that or removing the helmet hook on the right side.{/quote]
I had the same problem so I just removed the helmet hook. Wasn't using it anyway.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • TexasKZ
  • TexasKZ's Avatar
11 Dec 2015 18:18
#702782
Most any shock will be stiffer than worn out factory shocks. Do you know which make and model the shocks were made for? If they were made for a bike much heavier than yours, there may be no way to lighten them up enough. If they are designed for one only slightly heavier, the manufacturer may be able to supply more appropriate springs.
If they are Ohlins or KYB, the nitrogen in the cylinder is under very high pressure and should not be jacked with.
  • missionkz
  • missionkz's Avatar
12 Dec 2015 07:49
#702826
I have an old set of 13" Boge Mulholland shocks from a different KZ project. Probably 18,000 to 20,000 miles on them. Not sure anymore.
They are supposed to be rebuildable. Who does that?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Dec 2015 11:51
#702858
kaw-a-holic has a guy that does them.
  • kaw-a-holic
  • kaw-a-holic's Avatar
12 Dec 2015 17:09
#702887
swest wrote: kaw-a-holic has a guy that does them.
You can try Chris Livengood. Here is his site. He rebuilds RFY's into better shocks. Looks like he is due to come out with his own here very soon. Made 100% in the USA. Here is a link to his site.
chrislivengood.net/wp?raf=ref0457299
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • razmo99
13 Dec 2015 12:12
#702983
Honestly I dont even know what they are, got them with a purchase for some z550 parts, they are brand new from a site called www.japbikespares.com
I have looked around and apparently their shocks are rubbish, I would have to agree.
For now I have put the originals on, and will keep then till I get a set a hagon's
The stock ones still work good their are Showa's with 4 adjustable dampening settings.
- Z500 B4
-GPZ900R A9-10 ish
  • floivanus
  • floivanus's Avatar
13 Dec 2015 13:11
#703000
Guy basically has that market cornered BUT they are easy shocks to rebuild and modify yourself: there's a post on 'do the ton' by crazypj that shows how to do it.
Past; 78 kz1000, 83 kz550
Andrew
