Boxes of basket case
- 52 Tele
- Boxes of KZ
21 Nov 2015 13:29
I am putting together a bike from boxes of stuff and my plan is to assemble the bike the way I want it to look then tear it down, cut off whatever tabs I don't want, paint and reassemble. I started with taking "D" parts and putting them on an "H" frame and discovered that's not gonna work. Everything I have with the exception of an extra frame and motor is from a "D".
I took the wheels to a shop and got the bearings replaced and new rubber. Today, when I was trying to fit the tail back together the rear wheel assembly would not fit between the swing arm forks...WTFO? I'm thinking I don't have something together quite right. I have been using a Clymer manual and referring to the Kawasaki parts diagrams online but I haven't been able to locate the diagrams for a D yet.
Anybody got a solution to this problem? Here are some pics....
Attachment image-3.jpeg not found
Attachment image-4.jpeg not found
Attachment image-5.jpeg not found
Attachment image-6.jpeg not found
Robert
It's a fine line between clever and stupid
- 52 Tele
- Boxes of KZ
Re: Boxes of basket case
21 Nov 2015 13:37
Anybody know what this little fella is and where on the bike it goes?
Attachment image-7.jpeg not found
Robert
21 Nov 2015 15:22
Looks like a front axle spacer. Nice looking rims.
- floivanus
21 Nov 2015 20:48
My guess is what steve said, but I'll add that it goes just inside that chrome cover, which I believe also goes on the front wheel? Correct me if I'm wrong
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- rstnick
22 Nov 2015 03:35 - 22 Nov 2015 03:56I haven't been able to locate the diagrams for a D yet.
D models are shown as SR on the Kawasaki parts site.
Because you are fitting a 650D model rear wheel in an H model frame, the spacers are probably wrong.
Compare the diagrams of the D & H models, and find the differences.
This post has D model diagrams, and some info on the
forums.kz650.info/index.php?topic=14866.0
D rear wheel:
Here's an H rear:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 22 Nov 2015 03:56 by rstnick.
- rstnick
22 Nov 2015 03:52 - 22 Nov 2015 03:53
Hard to compare the parts above, as the part numbers are not shown, but the spacer on the far right when looking from the rear (next to the axle in the dia.), #14 in the D diagram, and #92027 in the H diagram, look to different in shape and size.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 22 Nov 2015 03:53 by rstnick.
- OnkelB
At least one culprit is that chrome cover, it does not belong on the rear wheel, it sits on the right side of the front wheel.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 22 Nov 2015 07:42 by OnkelB.
- 52 Tele
- Boxes of KZ
22 Nov 2015 07:42
I took the wheels and parts that looked like they should be attached to the wheels to a shop for tires and bearing replacement. They did in fact put the front hub dust covers on the rear wheel. There's a flat dust cover and the dome dust cover and bothe were stacked on the right side of the rear hub. I removed them and, viola, it fits! It' missing a spacer or something though cuz there is open space between the brake caliper housing axle attachment and the bearings. Thanx to rstnick for pointing out the SR on the kawi parts diagrams! I should be able to verify all the parts thru that.
Robert
- 52 Tele
- Boxes of KZ
22 Nov 2015 07:52
Thanx. I have boxes of D and H parts that are all jumbled together. I do have dual discs up front on the wheel I'll use. I took the forks to a shop for service and seal replacement. I read a horror story about tackling that oneself without the right tools and decided it better to avoid throwing stuff and kicking the dog so I caved on that... I should get those and a new rear sprocket in a week or so and then I'll put the front together and see what I got...
Robert
- z1kzonly
22 Nov 2015 11:11From the side it looks like a piston for a brake caliper! Is it solid? Or a hole thru it?52 Tele wrote: Anybody know what this little fella is and where on the bike it goes?
- rstnick
Good catch!
I saw that picture, and didn't even notice.
:laugh:
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
