1982 gpz 750 brakes
- rinferno
Re: 1982 gpz 750 brakes
27 Nov 2015 12:54 - 27 Nov 2015 12:55
Well I did put on new galfer brake lines a bit better but the problem still exists. Upon dis-assembly, pistons are piited on the sides but they don't leak. Pistons on Xmas list. I'll see if that has any affect when I install them. I'll update with result. To this point I have tried every method of brake bleeding always the same result, we'll see after new caliper pistons. Brake lever is about 2/3 through before you get any firmness on the lever.
1982 gpz 750
Last edit: 27 Nov 2015 12:55 by rinferno.
27 Nov 2015 13:03
Did you try pumping them and hold?
- rrsmsw9999
27 Nov 2015 14:29
That was my thought too. You need pressure pop the bleeder, let lever pull in and keep it there, tighten bleeder, pump again repeat. If you are just pumping with the bleeder open and then closing bleeder without the lever being held it won't work right. That being said if you have a bad line replace it. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
27 Nov 2015 14:56
I pump it 5 or 6 times then hold it for 30 seconds, then let it out slowly.
- DFIGPZ
27 Nov 2015 14:57
does 82 GPZ750 have anti dive set up ?
1984 750 Turbo
- rinferno
29 Nov 2015 12:44
Thanks, everyone for your help, my results have been the same regardless on how i bleed the brakes. I have tried them all. It doesn't have and dive forks, I know Yamaha had those on the XJ series in the same era.
1982 gpz 750
29 Nov 2015 14:54
So again, the sponginess could be due to the caliper pistons parking too far away from the discs. You may want to tie back the brake lever again to see if you can get the pistons to creep closer to the discs. I've seen this issue before when K&L caliper seals were used instead of OEM. Pulled some serious hair out over that one.
- redhawk4
29 Nov 2015 15:56
I couldn't get my KZ1000A2 brakes to bleed after doing a double disc conversion, I had a vacuum bleeder and just kept pulling fluid through to no avail. My problem was solved when I realized, that the splitter on the front was the issue. As the bike was sitting the front was higher than the back where the connection to the MC brake lone is. I unbolted it from the frame and positioned it so it was uphill all the way to the MC. Things improved immediately, but it still took a time to work all the air out by pumping it and eventually tying the lever back. What amazed me was how much difference the tiniest of bubbles seen coming up into the MC reservoir made. I forget the layout of the GPz750R1 splitter I know it's different because, the brake light switch is by the lever, not in the splitter, but check to make sure there is no air trapped there. A bubble the size of a pinhead will seriously effect your braking more than you could ever imagine.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
29 Nov 2015 16:04
You can bleed at the banjo bolts starting at the bottoms and working to the top. My M/C gave me problems until I took it apart and cleaned everything piece by piece. That was over two years ago.
- rinferno
17 Jan 2016 09:35
Well I'll update on whats happened, after pretty much rebuilding the front brakes, this is what finally worked for me. I "PUMPED" up front brake and held the lever pinned to the handlebar then zipped tied it. I let it set that way for almost 2 days. Removed the zip ties and that finally worked. Tried this before but didnt tie the lever in pumped up mode. Thanks for all the help and tips.
1982 gpz 750
