1982 gpz 750 brakes
  • rinferno
  • rinferno's Avatar Topic Author
1982 gpz 750 brakes
25 Oct 2015 14:08
#695936
I have bled the front brakes, soft lever. almost to the handlebars before any pressure on lever. no air out of calipers no leaks at banjo fittings or hoses. I'm at a loss, never had this much trouble with bleeding brakes. Tried every trick in the book. any ideas? Rear brake was no problem at all.
1982 gpz 750
  • Nessism
  • Nessism's Avatar
Re: 1982 gpz 750 brakes
25 Oct 2015 17:17
#695954
What if anything have you done to the brakes? Have you ever torn down the system to clean out the crud?
The following user(s) said Thank You: rinferno
  • rinferno
25 Oct 2015 17:33
#695956
Yes, from master cylinder to calipers, removed pistons and cleaned calipers and pistons. Actually pretty clean, checked and cleaned banjo bolts and checked orifices. cleaned pistons some pitting, but not leaking fluid at calipers. I have brake lever tied to handlebars will check tomorrow to see if there is any improvement.
1982 gpz 750
  • Markovich
  • Markovich's Avatar
25 Oct 2015 19:25
#695961
I have been having the same problem for some time now. Bled them at least 6 times. Reverse bled them. No change. I am going to try a method I read on another forum. Disconnect from the master, remove air from lines , reconnect to master and try to get a firm brake. I even changed 2ea masters. I will be watching for your results. I will let you know if I have success as well. Good luck.
1990 KZ1000P, 72k miles, 10 years in storage, new, bars, tires, chain and sprockets, seat, carbs cleaned, police equipement removed.
  • chirpy999
  • chirpy999's Avatar
26 Oct 2015 08:30
#696025
Hi to both of you, have you cleaned the seal grooves out? I spent mucho coin on my brakes , trying different calipers master cylinders and linesbefore being advised by a moto morini guru to get my grooves cleaned . he was correct no problems since.
  • Nessism
  • Nessism's Avatar
26 Oct 2015 08:37
#696027
Sponginess at the lever is typically because the caliper pistons have parked too far back into the caliper body. You need to get them to move closer to the rotor. Tying back the hand lever against the handlebar is to increase pressure in the system for a long period of time. With the lever tied back over night the caliper pistons will (hopefully) slowly creep closer to the disc, and eliminate or at least greatly improve, the sponginess. Needless to say you have to make sure the master cylinder and calipers are clean, particularly the small return port in the master. Fresh brake lines, hopefully some teflon/stainless braided type, are installed too. They don't expand as much as rubber lines and provide a more firm level feel.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
26 Oct 2015 10:12
#696032
Have you tried a vacuum bleeder?
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Tyrell Corp
  • Tyrell Corp's Avatar
26 Oct 2015 10:54
#696039
+1
I had a difficult one recently, I removed the caliper and tapped the hoses and caliper body with a screwdriver and lifted it up to help the bubbles float to the top. Bingo, a couple of big bubbles and sorted.
If you very gently squeeze the brake lever you can let a some bubbles out, then button it up, bounce around on the forks, lean it from side to side and repeat. Put a cover over your tank and clocks as it is easy to let some brake fluid spurt out as you work the lever.
  • rinferno
26 Oct 2015 17:41
#696087
I received this message from another forum, from their moderator. I will try this method, hopefully this will work, will keep you guys updated.
The front brake bleed on a Kaw is complicated by the fact that the two lines go into a combiner and then come out with two lines. Generally, leave one bleed valve closed and use a Mity Vac on the other to DRAW FLUID THROUGH... keep a towel under the brake reservoir and keep it from going dry in the process. Thanks George! @ www.wgcarbs.com
1982 gpz 750
  • DFIGPZ
  • DFIGPZ's Avatar
26 Oct 2015 18:49
#696094
and why is this in the ENGINE Section ??????
1984 750 Turbo
  • rinferno
27 Oct 2015 17:49 - 27 Oct 2015 17:50
#696202
Reversed bled the brakes, fluid changed several times from both calipers no bubbles, noticed while depressing brake lever noticed hoses expanding, so at this point that's what I think so far. put wood blocks on calipers expanded pistons out and re-bled system same result soft lever, i does complete stop the bike but lever is almost to the handlebars.
1982 gpz 750
Last edit: 27 Oct 2015 17:50 by rinferno.
  • chuck356
  • chuck356's Avatar
27 Nov 2015 10:15
#700792
I had the same problem on my '82 KZ750R1, new hoses solved my issues.
