fork oil seal replacement
- blink543
21 Oct 2015 20:46
I'm planning on replacing the seals and oil in my kz650b forks soon because I have a suspicion the seals are wearing out. I read online about it and people are saying it's a real pain in the ass. Why is that?
Adam james
- Bozo
- Ride it like u stole it
Re: fork oil seal replacement
21 Oct 2015 21:41blink543 wrote: I'm planning on replacing the seals and oil in my kz650b forks soon because I have a suspicion the seals are wearing out. I read online about it and people are saying it's a real pain in the ass. Why is that?
Suspicion?
If you haven't done it before its a good idea to watch someone do it or follow the manual carefully, especially when filling the oil (if you change the seals , change the oil and clean the internals), Check if the bushes need replacing.
The reason why people are scared because it can be an act balancing the bike (I use a stand under the motor) so it doesn't fall when removing a spring etc.
- ThatGPzGuy
22 Oct 2015 01:46
It also helps to have access to an impact to get that bottom bolt out. Otherwise, you'll need the factory tool or you will need to improvise. The rest is fairly straightforward. The forks themselves are fairly simple.
However, unless they are leaking your suspicions are probably incorrect. Leaky fork seals are fairly obvious...
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
22 Oct 2015 03:34 - 23 Oct 2015 03:18
The first fork can be a bear, but the second one should be easy. The bottom allen bolts can be difficult to remove ---- as mentioned an air impact gun is typically the quickest way to get them out (forks assembled w spring pressure on the inner cylinders). Use an 8mm brake caliper socket or hardened allen socket. A cheap chinese allen tool may get twisted & ruin the bolt heads.
Fork tool. KZR topic w photo by 650ed --- the 650B is probably the same as the C1 .
Last edit: 23 Oct 2015 03:18 by martin_csr.
- jakedude
22 Oct 2015 04:22
It's not that the job is particularly difficult. Yeah you need to make or buy a few specialty tool. Don't buy because the tools are simple to make. Yeah you have to support the bike with the forks off but again not difficult. The reason most people don't like to do the job is that it can be rather messy. Even with care fork oil seems to get everywhere.
Nothing lasts, nothing is finished, and nothing is perfect.
- mtbspeedfreak
22 Oct 2015 05:12
Does a KZ900 have replaceable bushings? Or are seals, springs, and oil the only replaceable items?
2000 ZRX 1100
1976 KZ 900- Daily Driver
- blink543
22 Oct 2015 12:16ThatGPzGuy wrote: It also helps to have access to an impact to get that bottom bolt out. Otherwise, you'll need the factory tool or you will need to improvise. The rest is fairly straightforward. The forks themselves are fairly simple.
U mean the bolts that hold that thing that goes through the front tire that holds the speedometer drive on?
Adam james
22 Oct 2015 12:47 - 23 Oct 2015 03:12
There are axle holder clamp bolts or nuts & the axle goes thru the speedo drive unit.
He means the bottom allen bolts on the forks.
You have to remove the axle holders first to gain access to the allen bolts --- aka fork cylinder bolts.
Last edit: 23 Oct 2015 03:12 by martin_csr.
- blink543
22 Oct 2015 13:24martin_csr wrote: There are the axle holder clamp bolts & the axle goes thru the speedo drive unit.
These won't come off. They are regular thread right? Not reverse?
Adam james
- blink543
22 Oct 2015 13:49Bozo wrote:blink543 wrote: I'm planning on replacing the seals and oil in my kz650b forks soon because I have a suspicion the seals are wearing out. I read online about it and people are saying it's a real pain in the ass. Why is that?
Suspicion?
Looking online the bushings for my 78 kz650b don't even exist. I should probably just sell the thing. Parts are getting scarce and aren't being produced.
Adam james
- RonKZ650
22 Oct 2015 17:11 - 22 Oct 2015 17:12Those are your axle nuts. They are normal right hand thread. They are tightened to a pretty fair amount of torque so take a little effort, and the 2 nuts down on the bottom of the forks when tightened clamp the axle nuts and the big axle nut can't be loosened until the smaller clamp nuts are loosened first. However to do fork seals no reason to loosen the big axle nuts, just remove all 4 bolts on the bottom of the two fork legs, the clamps can be removed and the whole wheel just falls down off the forks. Be sure and get a manual before doing any work or you're most likely going to do more damage than good. Fork seals are not hard on the 650, but there is a procedure, just like any other job.blink543 wrote:martin_csr wrote: There are the axle holder clamp bolts & the axle goes thru the speedo drive unit.
Last edit: 22 Oct 2015 17:12 by RonKZ650.
- redhawk4
22 Oct 2015 18:41
A lot of KZ650 parts are the same as for the KZ1000's so most frame and wheel parts are not hard to come by. I did the fork seals on my KZ650B1 when I got it, it was pretty easy really, particularly with an air wrench to crack the Allen bolts in the bottom of the legs. Once you drop the front wheel you will see them in the center bottom of the fork leg. As someone else said, make sure you undo these with the spring pressure on. The air wrench is the key, otherwise the inners will turn and while there are special tools and a makeshift way using a whittled down broom handle that they show in the Haynes manuals, the air wrench is the way to go. I didn't find the seals hard to remove.
One thing to be careful of is the bike coming forward off the center stand while you are doing the job, that made things exciting if I remember
. I'm doing mine on my KZ1000 in the next few days, I'm going to hook my engine hoist up to lift the front, so that can't happen.
If you get a manual so you get an overview of what you are doing it's really a pretty easy job, just make sure you have the bike supported well and take your time. It's a good idea to remove your gas tank to avoid that getting damaged when working top sides on the fork caps, depending on your bars you usually have to move them out of the way.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
