Keys dont float and gas goes boom!
- davido
23 Sep 2015 10:41 - 23 Sep 2015 10:42
Im planning to weld on my fuel tank (fitting a flush filler cap). Common sense dictates that this could be dangerous. Ive cleaned it out with soapy water and left the garden hose running through it for half an hour.This was at the start of the summer and since then its been sitting atop the bike in the basement , totally open. Fuel cap,petcock and sensor all removed.
I want to be very sure that its not going to explode when I touch the welder to it. So, my reckoning is to see if it will explode out in the garden first. A controled explosion of sorts. Though a non explosion is what Im aiming for.
Is this a completly dumbass idea??
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Last edit: 23 Sep 2015 10:42 by davido.
- Kidkawie
- I bleed premix
Re: Keys dont float and gas goes boom!
23 Sep 2015 10:49
I welded up a 76 KX tank a few years back, just washed it out real good, then hit it with a small propane torch to see if anything was still flammable. Got nothing. If there were flammable fumes, they would just burn off through the opening, not explode.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- Tyrell Corp
23 Sep 2015 10:56
I've had a tank welded, no probs, just thin metal and very easy to burn through.
Best to fill tank with CO2 or an inert gas if you can.
23 Sep 2015 11:20
i have welded several tanks and never had one even give me a puff,just hosed em out with water.
i have a buddy that lights matches and throws them at the gas cap hole until one goes in :evil: !
i have heard that a garden hose taped to your running car exhaust and ran into your tank will evacuate the fumes sufficiently.
but a wash with water and pass a flame over the gas cap like kidkawie said it won't blow.
- Tyrell Corp
23 Sep 2015 11:33
That works too, I didn't suggest it as inert gas seems a lot safer...I had CO poisoning last year and it can be a killer.
- davido
23 Sep 2015 21:28 - 23 Sep 2015 21:28
OK.Thanks for the tips people. If you dont hear from me again,itll mean my tank wasnt as clean as I thought!!!!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Last edit: 23 Sep 2015 21:28 by davido.
- floivanus
23 Sep 2015 21:40
I had a honda tank that I flushed out and left open go foom on me when i started to weld studs to a good size dent. Put the stud gun away without using the slide hammer one time. Popped the dent out lickity split
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- davido
24 Sep 2015 10:47
So you would recommend it for dent removal? Thanks for using 'Lickity split'. Havent heard that in ages!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- 80B4
24 Sep 2015 13:20
"Lickity split" isn't that a LGBT phrase now?
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- pete greek1
25 Sep 2015 10:11, :laugh: :laugh: :laugh: :laugh:80B4 wrote: "Lickity split" isn't that a LGBT phrase now?
Pete
25 Sep 2015 13:35
:sick:
