front master Leaking...
  • razmo99
  • razmo99's Avatar Topic Author
21 Sep 2015 13:31
#691231
So this all started when I decided to replace the seals in my front brake callipers(currently not leaking).
I also decided to clean out the front master cylinder as it had some red gunk in it. upon trying to bleed the system the brake lever wouldn't get to that rock solid feel that it had before.
I decided then that the piston must be damaged and ordered a rebuild kit off of E bay. upon installing the kit it still leaks but only when the lever is applied. The bore has some red corrosion but no serious pitting from what I could see.
Does anyone have any tips for getting he piston to seal, I have looked at honing the bore but am unsure how to go about it.
I can upload pictures if that would help.
- Z500 B4
-GPZ900R A9-10 ish
  • jackleberry
  • jackleberry's Avatar
Re: front master Leaking...
21 Sep 2015 13:46
#691234
What leaks and from where?
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • razmo99
21 Sep 2015 14:01
#691237
The piston and from the bottom of the dust seal
- Z500 B4
-GPZ900R A9-10 ish
  • jackleberry
21 Sep 2015 14:18
#691240
If I understand you correctly, the master cylinder did not leak until you put a rebuild kit in? Well, that's often the case with these rebuild kits. Why not just put the old parts back in that didn't leak?
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • razmo99
21 Sep 2015 15:52 - 21 Sep 2015 22:06
#691254
That was the case originally before I cleaned it. After it leaked.
- Z500 B4
-GPZ900R A9-10 ish
Last edit: 21 Sep 2015 22:06 by razmo99.
  • razmo99
21 Sep 2015 23:24
#691282
Ok So i took some photos. What do you think still usable?
Attachment IMG_0875.jpg not found
Attachment IMG_0876.jpg not found
Attachment IMG_0877.jpg not found
Attachment IMG_0887.jpg not found
Attachment vlcsnap-0247-01-07-18h36m05s480.png not found
Attachment vlcsnap-2978-01-23-22h25m11s770.png not found
Attachment vlcsnap-3645-09-15-01h02m01s145.png not found
Attachment vlcsnap-5803-04-16-12h35m07s591.png not found
Attachment vlcsnap-8308-02-10-14h40m36s641.png not found
Attachment vlcsnap-8714-05-29-02h11m34s324.png not found
- Z500 B4
-GPZ900R A9-10 ish
  • Rasp11
  • Rasp11's Avatar
22 Sep 2015 02:50
#691294
You need to hone that bore out, that's why it's leaking.
  • jackleberry
22 Sep 2015 07:13 - 22 Sep 2015 07:14
#691344
Heh. No, that thing looks like it sank with the Titanic. Must have had lots of water in the fluid for a long time. You're going to have to at least soak it in acid or something to get all that corrosion off, and the bore is never going to be the same again. I think a new master cylinder would be cheaper than a hone and your time, so in this case I'd just get a "new" one if I were you.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
Last edit: 22 Sep 2015 07:14 by jackleberry.
  • Tyrell Corp
  • Tyrell Corp's Avatar
22 Sep 2015 07:54
#691349
You might be able to lightly hone it, but that looks pretty bad. I wouldn't use acid.
They can be reconditioned with an insert fitted.
Those front master cylinders are fitted to a lot of the kz fours. If you replace with another then make sure the cylinder bore is the same, I think 5/8.
  • razmo99
22 Sep 2015 23:17
#691473
Does anyone have any good methods for lightly honing it?
- Z500 B4
-GPZ900R A9-10 ish
  • jackleberry
23 Sep 2015 07:26
#691506
razmo99 wrote: Does anyone have any good methods for lightly honing it?
Well you could either buy a proper hone of the appropriate size (but this will be a good fraction of the cost of a "new" master cylinder), or you could try to improvise something. Perhaps a giant cotton swab (in think there are some cylindrical ones in dremel kits which would be around the right size (although with too short a shaft) and some Mother's Aluminum Polish. Mother's is pretty good at getting corrosion off aluminum--you might be able to get it mostly smooth with some on a rolled up paper towel.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • pete greek1
  • pete greek1's Avatar
23 Sep 2015 08:34
#691510
No eBay APP ID and/or Cert ID defined in Kunena configurationAnother option would be to just buy a new one, 8 yrs. ago when my front M/C started leaking I started looking for a rebuild kit & they were around 39.00, & I ran across this place & for 49.00 I bought a brand new M/C with free shipping, I haven't had any problems with it in 8 yrs. I don't know if it would be free shipping to Australia, but you could ask
& new always looks better than old, B)
Pete
