84 KZ700 handlebar suggestions?
  • Treeman
  • Treeman's Avatar Topic Author
  • 1984 KZ 700 A1
05 Sep 2015 05:27
#688707
I have been looking for handlebars with no rise and shorter pullback that will give me a more forward riding position. The problem I am running into finding a set that gets the brake assembly side the top fork tube mount. Any suggestions?
1984 KZ700 A1
2005 Harley Softail Springer Classic
Palmyra, NY
  • Nessism
  • Nessism's Avatar
Re: 84 KZ700 handlebar suggestions?
05 Sep 2015 05:49
#688712
Treeman wrote: The problem I am running into finding a set that gets the brake assembly side the top fork tube mount. Any suggestions?
Having a hard time understanding the highlighted part. Can you clarify?
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Sep 2015 06:12
#688715
Yes, please do. Pics?
  • Treeman
  • 1984 KZ 700 A1
05 Sep 2015 06:29
#688717
Sorry about that.......The master cylinder and brake fluid reservoir come in conflict with the top of the front fork when looking to find a bar with not rise. It seems to me a bar that is a little longer may put the brake assembly outside of a conflict and I was curious if any one found a bar that works.
1984 KZ700 A1
Palmyra, NY
  • Nessism
  • Nessism's Avatar
05 Sep 2015 06:50
#688718
What bars do you have installed in that photo?
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • martin_csr
  • martin_csr's Avatar
05 Sep 2015 07:35 - 05 Sep 2015 07:38
#688727
A photo of the handlebars might be helpful --- in case superbike bars are already installed, in which case the choices would be somewhat limited. The mc doesn't seem to be very large, but you might be able to find something smaller or maybe get one having a separate reservoir from the piston assy. ???
Last edit: 05 Sep 2015 07:38 by martin_csr.
  • barney
  • barney's Avatar
05 Sep 2015 13:30
#688772
I'm running super bike bars with a similar set up on My ELR. You may want to look at Renthal bars (motocross stuff)
Barney
