Rear wheel bearing driver
  • pbmax
  • pbmax's Avatar Topic Author
30 Aug 2015 11:32
#687856
What do you guys use to drive in rear wheel bearings? The largest socket I have is 32 mm and its a bit too small.
Is it safe to tap around the outer race?
1979 kz750 twin.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Rear wheel bearing driver
30 Aug 2015 11:40
#687859
I use the old bearing then tap around the outside race to be sure it's seated.
  • Tyrell Corp
  • Tyrell Corp's Avatar
30 Aug 2015 11:48
#687864
I lightly clean up the inner bearing housing with some wet and dry and dig out the circlip groove, they can get a bit of alloy corrosion here. The bearings are a tight fit anyway, also make sure your inner bearing spacer is positioned right.
  • pete greek1
  • pete greek1's Avatar
30 Aug 2015 12:31
#687876
It also helps if you put the bearing in the freezer for a while then lightly grease the race before installation
Pete
30 Aug 2015 15:19
#687890
In the past I used a short piece of PVC pipe that was just a tiny bit smaller in diameter than the OD of the outer race. I put a small block of wood between the hammer and pipe and tapped lightly around the circumference to push the bearing in. Just a little grease on the outer part of the outer race helps too. Ed
  • martin_csr
  • martin_csr's Avatar
30 Aug 2015 15:23 - 30 Aug 2015 15:25
#687891
I got a bearing driver set on eebbaayy for pretty cheap. Something like this --- bearing race and seal driver set
Apply a small amount of grease to the wheel & bearing.
Last edit: 30 Aug 2015 15:25 by martin_csr.
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
03 Sep 2015 05:11
#688406
I have used this with great success.
www.motionpro.com/motorcycle/partno/08-0551
'85 GPz550(ZX550-A2)
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Sep 2015 06:11 - 03 Sep 2015 06:12
#688413
The PVC method is safer. It is too easy to get it cocked to one side and mung it up. Take your time and try it 100 times if needed. :whistle:
Last edit: 03 Sep 2015 06:12 by SWest.
  • JimB
  • JimB's Avatar
Re: Re:Rear wheel bearing driver
03 Sep 2015 07:31
#688428
I recently did my bearings and I used a threaded bar, some washers and nuts and pulled them in so as not to damage the bearings. It costs about $5 dollars of hardware.
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
  • 80B4
  • 80B4's Avatar
03 Sep 2015 07:43
#688432
This has come up in the past and I have done some research into the proper tools and techniques to install wheel bearings. Older Japanese bikes use centre spacers that are wider than the distance between the bearing seats in the hub. The OEMs use flat faced bearing drivers to push and support the bearing inner and outer race at the same time. When the inner race makes contact with the centre spacer, the outer race cant be driven to the bottom of the bearing pocket. If you install new bearings and there is binding you should start over with new bearings and use flat faced bearing driver / supports.
1980B4 1000
1978 Z1R
1978 B3 750
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Sep 2015 08:00
#688437
If new bearings are to be used, it doesn't matter if the old one is damaged. Should be replaced with modern ones anyway. If not the proper tools need to be used.
  • jakedude
  • jakedude's Avatar
03 Sep 2015 09:21
#688452
I have used a socket of the appropriate outer diameter.
Nothing lasts, nothing is finished, and nothing is perfect.
