1978 KZ 1000 Rear Master Cylinder
  • gotmoto
  • gotmoto's Avatar Topic Author
24 Aug 2015 16:08 - 24 Aug 2015 16:08
#687017
78 Chain drive single rear disc. RH. My rear master cylinder builds up pressure and doesn't release. I will bleed the pressure at the caliper and then it seems to work for a while, a couple of hours of riding stop and go, and then pressure builds up again. Has anyone seen this? Will a master cylinder rebuild kit fix this? Is it rust, debris? Not able to find an OEM replacement. Would prefer to avoid modifications to accommodate a different make or model master.
Last edit: 24 Aug 2015 16:08 by gotmoto. Reason: Mis-spelling
  • DoctoRot
  • DoctoRot's Avatar
Re: 1978 KZ 1000 Rear Master Cylinder
28 Aug 2015 18:47 - 28 Aug 2015 18:48
#687547
sounds like your return port is clogged. take apart the master cylinder and look at the VERY tiny hole. make sure its super clean. since you're in there i would take apart and inspect and clean the entire MC and caliper.
Last edit: 28 Aug 2015 18:48 by DoctoRot.
The following user(s) said Thank You: gotmoto
  • davido
  • davido's Avatar
29 Aug 2015 00:39
#687566
+1 on that. Pull it apart and give it all a good clean.If youre careful you might get away with reusing the rubber bits and not need a rebuild kit.
If not,a rebuild kit isnt expensive and worth fitting for peace of mind if nothing else.
Good luck
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
