Help, lower fork bolt
  • pbmax
  • pbmax's Avatar Topic Author
24 Aug 2015 05:18
#686948
Part number 44041-040.
I ordered the correct part number for my 1978 kz750 b4 but the bolts don't fit either fork piston. I can turn them only about a quarter turn and they sieze up. It's like its the wrong thread size.
But as I said, its the correct new stock oem part.
Anyone have this problem?
  • martin_csr
  • martin_csr's Avatar
Re: Help, lower fork bolt
24 Aug 2015 05:49 - 24 Aug 2015 13:26
#686951
Did the new bolts come in an unopened Kawasaki package?
Will the old bolt threads thread back in?
Maybe try taking the old & new bolts to the hardware store to check them with a thread size gauge.
Last edit: 24 Aug 2015 13:26 by martin_csr.
24 Aug 2015 05:53
#686953
That's the same part number I used when I worked on my KZ650 forks, and the bolts worked perfectly. During assembly a non-permanent locking agent is used on the threads, so make sure the threads in the fork cylinders are clean. If they are clean and the allen bolts still do not thread in easily I suggest you take a fork cylinder and bolts to a machinist and have him check the threads with a thread gauge to make sure they match. It is possible you were shipped the wrong bolts. Ed
  • davido
  • davido's Avatar
24 Aug 2015 07:08
#686960
Maybe a PO changed the forks!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • pbmax
24 Aug 2015 07:23
#686961
Any tips on cleaning out old thread lock from inside what the manual calls the fork "piston and cylinder unit". It would be easy to clean a bolt, but this is down inside.
Thanks!!!
24 Aug 2015 07:26
#686962
You might be able to drag it out bit by bit using a dental pick. Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Aug 2015 08:09
#686969
Do you have the old bolt? You can cut a slot in it to chase out the threads.
24 Aug 2015 08:36 - 24 Aug 2015 08:38
#686970
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Aug 2015 09:35
#686986
Take the two bolts and interlock them together. That will tell you in a heart beat if the threads are the same. My daughter bought a Honda car. The PO munged up one of the spark plug holes. I took the plug that was only in 1/4 the way, used my grinder with a thin cutting blade, made two cuts along the length and used it as a thread chaser. I didn't suggest a tap because it is too easy to hog out too much material.
  • pbmax
24 Aug 2015 11:37
#687003
Thanks everyone.
I think its just the old thread lock. I'm scraping some out and the bolt is threading better.
