Motion pro custom clutch cables
  • 76KZ900
  • 76KZ900's Avatar Topic Author
15 Aug 2015 14:58
#685878
I have lowered bars on my 1100 Ltd with factory length clutch cable. Looks like I'll need at least 2" shorter cable. My factory one is frayed bad due to cable being too long. Anyone have personal experience with motion pro custom length cable? I've read mixed review's and wasted to hear from someone that used them. Also with putting lower bars on this bike is there a factory cable from earlier kx that would work? Thanks
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
76KZ900 (sold) regret
03ZRX1200R (sold) regret
83KZ1100 LTD Shaft
  • spdygon
  • spdygon's Avatar
Re: Motion pro custom clutch cables
16 Aug 2015 10:50 - 16 Aug 2015 10:50
#685960
DO NOT ORDER CUSTOM MADE....THEY WILL RUN ABOUT $45 EACH.
YOU CAN ORDER THE CLUTCH AND THROTTLE CABLES FOR A Z1R. THEY ARE 2" SHORTER.
I CHANGE MY 76 KZ900 ORIGINAL BAR TO THE SUPERBIKE TYPE ALONG WITH THE CABLES FROM A Z1R.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Last edit: 16 Aug 2015 10:50 by spdygon.
  • racer54
  • racer54's Avatar
16 Aug 2015 18:23
#686006
Are you talking about ordering OEM cables or Z1R spec cables from Motion?
  • 76KZ900
16 Aug 2015 18:33 - 16 Aug 2015 18:39
#686008
Could I get someone to take a pic of clutch cable routing ? If it hugs frame up to guages it's abot 8" to long. Previous owner had it looping out to bottom eye on triple tree.. Which I'm thinking is supposed to be for speedo cable. My factory cable is approx 54" long if that helps. That's the cable not the outer sleeve Thanks..
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
Last edit: 16 Aug 2015 18:39 by 76KZ900. Reason: More info
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Aug 2015 19:12
#686014
Are they routed along the back bone, above the tank gusset, then through the top triple clamp behind the head light?
  • 76KZ900
17 Aug 2015 06:10
#686056
swest wrote: Are they routed along the back bone, above the tank gusset, then through the top triple clamp behind the head light?
Im not sure what they you mean. It's only my clutch cable. It comes from clutch up left frame tube. I googled done pics to see routing. I really wanted to know if cable hugged frame tight all the way up to triple tree. In pics it looks like it does. My cable will be about 8" to long if that's the case. So I will need a custom cable unless I can find an oem cable that will work.
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
  • kaw-a-holic
  • kaw-a-holic's Avatar
17 Aug 2015 08:07 - 17 Aug 2015 08:13
#686065
Like spdygon said, if you order cables from Z1E for a 1980 Z1R they will be 2" shorter than a stock KZ1000. It sounds to me like the PO of your bike must have put what ever cable they had laying around.
Here are the matching throttle cables. Order 2 for push/pull.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Last edit: 17 Aug 2015 08:13 by kaw-a-holic. Reason: added link and info
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Aug 2015 08:25
#686068
You may not have a stock cable. Mine is a little short but workable. Pic of the cable? Does it have the center adjuster?
  • pete greek1
  • pete greek1's Avatar
17 Aug 2015 10:39
#686085
This is how it runs on my 80 LTD 1000, if that helps
Pete
  • pete greek1
17 Aug 2015 10:46
#686087
And from the triple tree to clutch perch
  • GPz550D1
  • GPz550D1's Avatar
17 Aug 2015 11:32
#686092
pete greek1 wrote: This is how it runs on my 80 LTD 1000, if that helps
Pete
Wow, that engine is beautiful!
1981 KZ550-D1
  • pete greek1
17 Aug 2015 13:27
#686105
Pete
I think I spend more time cleaning & polishing, then I do riding, :silly:
