gas tank and grab bar
  • kenfowler123
  • kenfowler123's Avatar Topic Author
06 Aug 2015 10:36
#684625
Need help again. I need to replace a gas tank on a 1982 KZ1100A shaft. I was wondering if anyone knew what other models are compatible for that model year. I also had the same question on the highly coveted rear grab bar for the same bike. I appreciate any help you guys can give me.
Thanks
1982 KAWASAKI KZ 1100 A SHAFT
  • GPzMOD750
  • GPzMOD750's Avatar
Re: gas tank and grab bar
12 Aug 2015 17:37
#685565
Is it a US model? I can't find a parts list for it. If it is the same as a '82 KZ750E Grip-Frame P/N 32109-1022. I know where there is one.
12 Aug 2015 18:46
#685573
The KZ1100-A2 (Shaft) part number (32109-1021) is different, although very close. I wonder what the difference is between the grab bars? Ed
Attachment 00003a-83.jpg not found
  • kenfowler123
13 Aug 2015 10:33
#685631
how can i tell if it is a us model
  • kenfowler123
13 Aug 2015 10:36
#685633
I have researched this myself and cannot come up with a definitive answer. It is very frustrating. I have been looking for this for over 6 years now. I know that they did come with a grab bar but finding one is impossible.
  • GPzMOD750
13 Aug 2015 10:49
#685635
The p/n is only of one digit so might just be the finish, the one I saw was chrome. This is the guy's ad that had it. Contact him and maybe you can figure out with measurements, etc. If it will fit.
www.ksl.com/?nid=218&ad=35462117&cat=&lpid=5&search=kz&ad_cid=7
  • mike1957
  • mike1957's Avatar
13 Aug 2015 18:21 - 13 Aug 2015 18:25
#685691
Here's the kawasaki part #'s for the gas tank.There are 2 p/n's one for a black tank
and one for a blue tank.You should be able to cross reference part numbers with
other yrs. and models.
51001-5211-H8 TANK-COMP-FUEL,EBONY
51001-1059-A8 TANK-FUEL,BLUE
mike1957
Last edit: 13 Aug 2015 18:25 by mike1957.
The following user(s) said Thank You: kenfowler123
  • mike1957
  • mike1957's Avatar
13 Aug 2015 18:38
#685694
1981-1983 Kz1100 lists the same part numbers for the black tank
type the part number into your browser .
mike1957
