.. stripped studs on fork
  • rlcarter
  • rlcarter's Avatar Topic Author
26 Jul 2015 09:16 - 27 Jul 2015 04:13
#682798
help.. i stripped the threads on the axle mounting studs on the fork.. can the studs be replaced or do i have to get new forks
1980 KZ1000 G w/carbs..
Last edit: 27 Jul 2015 04:13 by rlcarter.
  • missionkz
  • missionkz's Avatar
Re: shit .... stripped studs on fork
26 Jul 2015 10:21
#682813
rlcarter wrote: help.. i stripped the threads on the axle mounting studs on the fork.. can the studs be replaced or do i have to get new forks
Can you chase the threads with a slightly different pitch die and use new nuts?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
26 Jul 2015 10:25 - 26 Jul 2015 10:26
#682814
Could also consider helicoil or timesert (which are often used to restore stripped out female threads in the engine head where the cam caps bolt into).
Good Fortune! :)
Last edit: 26 Jul 2015 10:26 by Patton.
  • rlcarter
26 Jul 2015 10:47
#682819
guys the threads are partially missing. i could try a die to re thread it but that will make it smaller not sure it will be strong enough.. do you know if the stud is removeable
26 Jul 2015 11:44
#682823
The studs should be removable so that new studs may be fitted.
Will try to locate a part number.
Good Fortune! :)
26 Jul 2015 11:57
#682825
www.z1enterprises.com/ItemDetails.aspx?i...Fork&item=92004-1009
Could Google the part number for alternative sources.
Good Fortune! :)
26 Jul 2015 14:21
#682838
The studs can be replaced, and I believe you can still buy the correct studs from Kawasaki. See image below and notice they are not marked "not available." Please do yourself a favor and get a decent torque wrench or two so you can properly torque the fasteners on the bike. I have found it makes life much easier than trying to judge by feel when a fastener is tight enough but not too tight. Ed
Attachment 00003a-66.jpg not found
  • SWest
  • SWest's Avatar
  • 10 22 2014
26 Jul 2015 15:02
#682845
Please delete the first word in your topic line.
  • pete greek1
  • pete greek1's Avatar
26 Jul 2015 15:11
#682848
When installing the axle clamps , after you've replaced the studs , make sure the arrow on the clamps is facing to the front, and tighten the front nut 1st, to the right torque specs, then tighten the rear nut to the right specs, & there should be a gap at the rear of the clamp, but NOT the front of the clamp
Pete
  • SWest
  • SWest's Avatar
  • 10 22 2014
26 Jul 2015 15:18
#682852
That's right, it's explained in the MANUAL.
  • rlcarter
Re: .. stripped studs on fork
27 Jul 2015 04:21
#682928
sorry about the language steve. thanks for the info everyone .i got the bolt out and replaced with a new one. i have a manual and read about how to tighten the clamps . just wasnt sure if the studs weere removable. thanks again everyone.
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Jul 2015 06:47
#682942
Good man. This way when searching it will come up, haven't tried SHT. :lol: Are you sure it's the studs and not the nuts? You can get them at any hard ware store.
