zrx to kz 1000 front end converison
15 Jul 2015 06:37 - 15 Jul 2015 06:51
i done a zrx to kz front end conversion,
thought i would share some pics of how the gauge mounts turned out.
the zrx had an ignition loop and gauge mounts that had to be machined away first to slick up the upper triple.
i didn't get pics of the operation but it was pretty straight forward port-a-band and mill work :lol: .
here is a shot of a factory kz gauge mounting layout.
i machined up some weldment fittings (from a steering stem out of a zx636
) to match the internal hourglass shape of the factory mounts.
i found my data points and machined a couple notches in the upper triple to locate the fittings for welding.
and it was so stinkin (99 with a 110 heat index) hot i forgot to get any pictures of my gorilla aluminum welding before i machined it all off :sick: .
i milled the welds off the top, then used my head porting tools to do the fillets down the sides of the weldments.
then cleaned it up with a flapper wheel and the belt sander.
thanks for lookin,
thanks for lookin,
Last edit: 15 Jul 2015 06:51 by 531blackbanshee.
The following user(s) said Thank You: DoctoRot, pete greek1, NakedFun
Re: zrx to kz 1000 front end converison
15 Jul 2015 07:29
Always a pleasure to read your project posts
- gpz1170
15 Jul 2015 10:16
AWESOME
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
15 Jul 2015 12:59
Nicely done.
How is the speedo connection to the front wheel going to go?
15 Jul 2015 13:42 - 15 Jul 2015 13:43
thanks for the kind words guys.
texaskz,
that would be a good question for the guy who is building the bike. :whistle:
i'm just the fabricator :evil:
being as the zrx drives off the front wheel like a kz i'm going out on a limb and saying motion pro can prolly make a cable to work.
texaskz,
Last edit: 15 Jul 2015 13:43 by 531blackbanshee.
- DoctoRot
18 Jul 2015 05:55
I may be going a bit off topic here...
Unless he is planning to use an electric speedo from an LTD, I can see how that could work. Do you know if the ZRX uses the same reduction ratio as the KZ ?
531blackbanshee wrote: thanks for the kind words guys.
texaskz,
- kaw-a-holic
18 Jul 2015 06:10TexasKZ wrote: I may be going a bit off topic here...
texaskz,
I have read somewhere defore that the reduction ratios for most (keyword most) Japanese bikes are the same. The topic was brought up by me when someone was wanting to use a small simplified speedo on a KZ650. I believe it was one of the local FB forums I belong to.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- DoctoRot
18 Jul 2015 10:28 - 18 Jul 2015 10:46
The reduction ratio is the same if the wheels are the same size but since the zrx runs a 17" wheel it is going to be different. There is a Japanese company (name is escaping me right now) that makes OEM looking speedos for 18" and 17" wheels out there though.
Last edit: 18 Jul 2015 10:46 by DoctoRot.
- NakedFun
21 Jul 2015 18:19
It works. The way they do it is the speedo heads take a certain input speed (2440 Rotations Per Mile) IIRC. This is based off the designed overall wheel diameter. So as long as you use the stock front wheel, with the stock speedo drive, you should be good to go. Get Motion Pro to make you a cable in case of differences and you are there.
Very nice setup as always Leon. I ended up making those rubber isolated brackets that used the handle bar bolts that flushed the gauge cluster with the top triple. This looks stock though.
Cory
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
21 Jul 2015 18:39
Seems like Martin posted about this recently and mentioned that some speedometers even have the ratio stamped on them somewhere.
I wonder if riding helps memory, too?
