1978 kz650B front master cylinder diaphragm
  • skooterbum4real
  • skooterbum4real's Avatar Topic Author
29 Jun 2015 15:08 - 29 Jun 2015 15:09
#678752
I've just disassembled two front master cylinders for the kz650B, and on both units the diaphragms had dissolved around the outer edge. They had turned into a very soft tar like material.
I'm guessing age, or possibly someone had topped them off with an incompatible brake fluid. This leaves me with two unusable masters, unless I can find new Diaphragms.
Anyone have an idea where I might be able to find one of these ?? By the way, these are the tapered, or triangle type masters.
If not, does anyone have a good recommendation for the aftermarket masters that are available ??
1978 KZ650B 8,500 miles
1976 KZ750 Twin
SPECIAL CONSTRUCTION V-TWIN CHOP
Last edit: 29 Jun 2015 15:09 by skooterbum4real.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1978 kz650B front master cylinder diaphragm
29 Jun 2015 17:20
#678771
Too bad, I was going to offer you one I bought that was too small. It's rectangular. :(
The following user(s) said Thank You: skooterbum4real
29 Jun 2015 17:43
#678776
skooterbum4real wrote: I've just disassembled two front master cylinders for the kz650B, and on both units the diaphragms had dissolved around the outer edge. They had turned into a very soft tar like material.
These folks (see link below) say they have a reproduction diaphragm - part number 43028-1002. The diagram below shows that as the part number for the KZ650-B2 front master cylinder diaphragm. Ed
www.kurveygirl.com/shop/product_info.php?products_id=795
Attachment 00003b-13.jpg not found
  • skooterbum4real
30 Jun 2015 07:50
#678827
SWEET !! Thanks 650ed !!
I was sure there was absolutely no place to find them. I really appreciate this Ed !!
With the low mileage of this bike, and the great condition of the rest of the master cylinder, I was hoping to keep this original master on the bike.
1976 KZ750 Twin
  • skooterbum4real
04 Jul 2015 20:51
#679455
Got the diaphragms in today. Fast shipping, and a great fitting part !!
Thanks again for the heads up on these folks 650ed !!
1976 KZ750 Twin
05 Jul 2015 06:47
#679491
I'm glad I could help! Ed
