Speedometer cable help
- K.D. HART
08 Jun 2015 21:36
I built a bike out of some old Kaw parts and want to get the speedometer to work. These are the build parts I used for the bike.
***PARTS LIST***
1978 KZ1000 frame
1976 Z1 motor
1976 bodywork and controls
1980 1000C triple trees
1982 1000P forks, front and rear wheel
1982 GS1100 swingarm
I know I will need the longer C or P speedometer cable, but since the drive is from a 1982 1000P and the dash is from a 1976 KZ900 I'm not sure what cable I need. Will a J model speedo cable hook up to a KZ speedometer?
***PARTS LIST***
1978 KZ1000 frame
1976 Z1 motor
kzrider.com/forum/11-projects/594694-dir...to-kz1000-now#638488
kzrider.com/forum/11-projects/591120-i-f...rbo-drag-bike#606286
kzrider.com/forum/11-projects/589806-197...750-suspension-build
Re: Speedometer cable help
09 Jun 2015 05:46 - 09 Jun 2015 05:46
I think KZ speedometer cables are universal fit. You could compare them at Z1Enterprises.com or ask, or compare eebbaayy pics.
Last edit: 09 Jun 2015 05:46 by martin_csr.
09 Jun 2015 06:22
Franken Z' :woohoo:
- davido
09 Jun 2015 11:57
Most japanese bikes from that period have the same speedo fittings as far as I know,you probably dont even need a Kawasaki one.The only differences would be in length. If you run a piece of heavy electrical cable down the front of the bike and cut it to size,you can take it to a bike shop and get the speedo cable at the length you need.
The other thing to think about is,will the drive in the 82 1000p wheel be a compatable with the 76 speedo. Even if you find a cable with the right connections and the right length, you could be working with different ratios which will make your speedo run too fast or too slow.
Or not!
Good luck
Or not!
Good luck
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
09 Jun 2015 13:11
Rim size.
- K.D. HART
09 Jun 2015 14:00davido wrote: Most japanese bikes from that period have the same speedo fittings as far as I know,you probably dont even need a Kawasaki one.The only differences would be in length. If you run a piece of heavy electrical cable down the front of the bike and cut it to size,you can take it to a bike shop and get the speedo cable at the length you need.
Or not!
Good luck
I thought the gear ratio was controlled by the drive unit on the wheel, not the speedometer?
- K.D. HART
09 Jun 2015 14:03The 1982 1000P wheels are 18 inch and I'm using the factory 1982 1000P speedo drive on the wheelswest wrote: Rim size.
- btchalice
11 Jun 2015 07:14
if it fits the wheel and reaches the speedo it will work , the top is pretty much universal the bottom i've seen with screw on and set screw styles but most import bikes use the same ratio . so whatever you have to fit your wheel should be fine.
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
The following user(s) said Thank You: K.D. HART
- K.D. HART
20 Jun 2015 14:55btchalice wrote: if it fits the wheel and reaches the speedo it will work , the top is pretty much universal the bottom i've seen with screw on and set screw styles but most import bikes use the same ratio . so whatever you have to fit your wheel should be fine.
Perfect. Thanks!!!!!!
