Chain Guard
  • Johnf41us
  • Johnf41us's Avatar Topic Author
Chain Guard
25 May 2015 12:59
#673664
Hello, I have a 1976 KZ900, I would like to put a chrome chain guard on anyone have any Idea's, it has a 630 chain on it and it rub's the guard and I can't put up with that. Please. Help
  • floivanus
  • floivanus's Avatar
Re: Chain Guard
25 May 2015 14:51
#673686
900 standard I take it? The ltds came with a chrome one from the factory. There were a few aftermarkets for the standard out there, I've got one kicking around, get a pic when i can
Past; 78 kz1000, 83 kz550
Andrew
  • Johnf41us
Re: Chain Guard
25 May 2015 16:45
#673701
Yes, it is a 900A4 1976, the plastic one i have rubs to much, I'll patiently wait for a pic,Thank You. John
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
Re: Chain Guard
25 May 2015 17:17
#673707
some after market ones out there but be careful some will rub on the frame and make holes
  • missionkz
  • missionkz's Avatar
Re: Chain Guard
25 May 2015 17:51
#673710
Many, it not all, the LTD versions came with a chrome chain guard.
However, seems like I recall the the LTD guard has one of it's mounting holes in a slightly different location the the plastic KZ guard.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • TexasKZ
  • TexasKZ's Avatar
Re: Chain Guard
25 May 2015 17:55
#673711
Why does the chain rub?
  • missionkz
Re: Chain Guard
25 May 2015 18:09 - 25 May 2015 18:10
#673716
My guard rubbed against the tire and consequently the chain, because I ran a fatter tire then the stock 400x18..... I was assuming the previous poster did too.
Bruce
1977 KZ1000A1
Last edit: 25 May 2015 18:10 by missionkz.
  • Johnf41us
Re: Chain Guard
25 May 2015 20:53
#673760
The original chain was a 530, the first owner switched it to a 630 chain, he also installed different shock's, which rub on the chain guard, and push it in slightly, causing the chain to rub in the tunnel of the guard
  • floivanus
Re: Chain Guard
25 May 2015 21:00
#673761
Original was a 630, I believe every kz above the 550s was a 630 chain
Andrew
The following user(s) said Thank You: Randombeat
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Chain Guard
25 May 2015 21:42
#673764
You're right. All had 630 chains. In 75 they went to the O ring chain that made it even fatter. The chrome chain guards don't have a inner side to them. I just made my own. I'd like a chrome one but keeping it clean will be more work.
  • TexasKZ
  • TexasKZ's Avatar
Re: Chain Guard
26 May 2015 05:39
#673784
Aren't 530 and 630 chains essentially the same width?
  • TexasKZ
  • TexasKZ's Avatar
Re: Chain Guard
26 May 2015 05:42
#673785
