Chain Guard
- Johnf41us
Chain Guard
25 May 2015 12:59
Hello, I have a 1976 KZ900, I would like to put a chrome chain guard on anyone have any Idea's, it has a 630 chain on it and it rub's the guard and I can't put up with that. Please. Help
- floivanus
Re: Chain Guard
25 May 2015 14:51
900 standard I take it? The ltds came with a chrome one from the factory. There were a few aftermarkets for the standard out there, I've got one kicking around, get a pic when i can
Past; 78 kz1000, 83 kz550
Andrew
Andrew
- Johnf41us
Re: Chain Guard
25 May 2015 16:45
Yes, it is a 900A4 1976, the plastic one i have rubs to much, I'll patiently wait for a pic,Thank You. John
- 9er rider
- Keep a cool tool
Re: Chain Guard
25 May 2015 17:17
some after market ones out there but be careful some will rub on the frame and make holes
- missionkz
Re: Chain Guard
25 May 2015 17:51
Many, it not all, the LTD versions came with a chrome chain guard.
However, seems like I recall the the LTD guard has one of it's mounting holes in a slightly different location the the plastic KZ guard.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Re: Chain Guard
25 May 2015 17:55
Why does the chain rub?
- missionkz
Re: Chain Guard
25 May 2015 18:09 - 25 May 2015 18:10
My guard rubbed against the tire and consequently the chain, because I ran a fatter tire then the stock 400x18..... I was assuming the previous poster did too.
Bruce
1977 KZ1000A1
1977 KZ1000A1
Last edit: 25 May 2015 18:10 by missionkz.
- Johnf41us
Re: Chain Guard
25 May 2015 20:53
The original chain was a 530, the first owner switched it to a 630 chain, he also installed different shock's, which rub on the chain guard, and push it in slightly, causing the chain to rub in the tunnel of the guard
- floivanus
Re: Chain Guard
25 May 2015 21:00
Original was a 630, I believe every kz above the 550s was a 630 chain
Andrew
Andrew
The following user(s) said Thank You: Randombeat
Re: Chain Guard
25 May 2015 21:42
You're right. All had 630 chains. In 75 they went to the O ring chain that made it even fatter. The chrome chain guards don't have a inner side to them. I just made my own. I'd like a chrome one but keeping it clean will be more work.
Re: Chain Guard
26 May 2015 05:39
Aren't 530 and 630 chains essentially the same width?
Re: Chain Guard
26 May 2015 05:42
