is this tire ruined?
  • gwyon
  • gwyon's Avatar Topic Author
20 May 2015 07:52
#672862
I bought some Pirelli Sport Demons for my 440 LTD, and I thought I'd try to put them on myself. First time. Watched a bunch of youtube vids and gave it a go. The rear tire went on fine. With the front tire, not only did I manage to pinch the tube, but I also put a small gouge in the side of the bead. If you pull back the rubber, you can see the plies. If this were your tire, would you run it? Or is it a $100 lesson?
Attachment IMG_3172.jpg not found
Attachment IMG_3173.jpg not found
1981 KZ440 LTD
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: is this tire ruined?
20 May 2015 08:20
#672869
How old is that tire? Looks like cracking too. If not you could use it as long as you have a tube and nothing else is wrong with it.
  • Nessism
  • Nessism's Avatar
20 May 2015 09:51
#672878
That nick may cause a slow leak if you are installing the tire tubeless. If using a tube I don't think you will have any issues.
