Front end swing arm and new wheels and tires
- StreetfighterKz
Re: Re:Front end swing arm and new wheels and tires
30 Apr 2015 10:33The only frame mod is was thinning down the brake pedal pivot mount about 1/8" which will hardly ever be noticed.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- davido
30 Apr 2015 14:09
but whats it from Doug??
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- StreetfighterKz
30 Apr 2015 14:19davido wrote: but whats it from Doug??
I guess that info would be helpful. The arm is from a '86-88 Gsxr1100 using a Zx6D wheel setup and the frontend is from a '89-90 Zx7R with a Zx11C wheel and brake system.
Long, long ago I had a build thread but I think it was about 3-4 forum versions ago.
Later, Doug
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- BLACKBEARD
Re: Front end swing arm and new wheels and tires
30 Apr 2015 20:37
As far as this bike we're gonna do shocks, rear sprocket(38 t) , and a set of smooth bores. However we are gonna start shopping for maybe a basket case or something of the sort. I guess the front end could be just about anything...just a matter of fitting a sleeve????
By the way I'm the wrench.
83 Gpz 750 named Rusty.
30 Apr 2015 21:02
There are some pretty sexy and great upgrades here. They're not easy or cheap. I don't look twice at the hack jobs. Anyone can do that.
01 May 2015 05:58
here is a thread showing what it takes to perform a front end conversion.
the method varies from triple to triple but the theory remains the same.
depending on weather thr donor lower triple has the stem welded in or pressed in is the big deciding factor on how to pull it off.
hth,
hth,
- BLACKBEARD
01 May 2015 06:52
Ok I was thinking along the same lines.
B.T.W. There will be no hack jobs going on here. Could you show me of an example of a hack job on the zr forum?
01 May 2015 07:05
Look around. I won't point them out. Guys tend to be very sensitive about their bikes. I've already insulted a few without meaning to. Trouble is though, the ones that fail just disappear.
Like one said, "he just picked up his ball and went home".
