KZ550 Cafe Rear Loop
  • DoctoRot
  • DoctoRot's Avatar
Re: KZ550 Cafe Rear Loop
07 May 2015 12:50 - 07 May 2015 12:52
#671027
Loquinho wrote: Well, for some reason, all the fabrication shops I call in town seem confused when I use the term "mandrel bending". I haven't yet found a place that can do this rear loop. It's getting a little frustrating. I don't want to cut up a bunch of small pieces and have them all welded together unless I have to.
Davido, what kind of shop did you have do yours, and if you id it yourself, how did you get the tight bends?
"Mandrel Bending" is where a mandrel (another tube) is put inside the tube you want to bend and then pushed around a die for the appropriate bend. This is necessary with large diameter tube that has a relatively thin wall thickness to keep it from kinking. Its something most fabrication shops will not be doing themselves.
If you just tell them you need some tube bent, or say you need some tube bent on a specific die radius, eg. 1" tube on a 6" radius they will know what you want. This is not mandrel bending, hence the confusion.
Last edit: 07 May 2015 12:52 by DoctoRot.
