Under mount rear caliper
  • spdygon
  • spdygon's Avatar Topic Author
18 Mar 2015 08:32
#664818
Post a wanted ad for a rear under mount caliper.
Can someone give me a idea of how I can make this happen.
Installing a Metmachex are but it was made for a undercount caliper.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Under mount rear caliper
19 Mar 2015 06:23
#664914
machine/fab a custom bracket to put it right where you want it.
maybe possible to cut down the brake you have and re-mfg it so you can bolt a newer caliper to it,perhaps?
  • Tyrell Corp
  • Tyrell Corp's Avatar
19 Mar 2015 17:07 - 19 Mar 2015 17:10
#664966
I'd get a tab welded on, underslung calipers always look odd to me on a kz. Sure I know it lowers the centre of gravity a touch.
Also bear in mind that cast alloy in the brake caliper body has greater strength in compression than in tension, conversely that nice looking custom tourqe arm will be the opposite, working better as a tie than a strut.
You can get the genuine mirrored metmachex stickers on ebay uk.
metmachex= metal machining experts
Last edit: 19 Mar 2015 17:10 by Tyrell Corp.
