80 series vrs. 90 series
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
01 Mar 2015 04:11
#663025
Have decided to run 100/90-19 on the front but with the rear, haven't decided whether going with a 80 series or 90 series 120 on the the back 18" wheel. Wheels are stock on my 77' KZ1000A. The 80 series tire ( Bridgestone BT-45's ) is an 1" shooter which would help with my foot placement.
Any problems running an 80 series profile tire on the back?
77' KZ1000A
  • floivanus
  • floivanus's Avatar
Re: 80 series vrs. 90 series
01 Mar 2015 04:35
#663027
The 80/90 series are the height of the sidewall as a percentage of the tread width. A 130-80-18 (making sizes up here) is about the same height as a 120-90-18.
If the tread width is the same, the 80/90 makes no real difference if it will fit or not, just in the height.
Past; 78 kz1000, 83 kz550
Andrew
The following user(s) said Thank You: PLUMMEN
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Mar 2015 05:11
#663032
No, it lowers gearing slightly. Only problem is finding a long lasting tire for these bikes that don't cost too much.
  • kzdcw
  • 77' KZ1000A
02 Mar 2015 04:02
#663147
BT45 120/80H-18 25.56" Diam.
BT45 120/90V-18 26.5" Diam.
Right at an 1" difference. So probably 1/2" shorter in height at the rear of the bike. Does that look about right?
77' KZ1000A
  • floivanus
02 Mar 2015 04:27
#663148
Yeah, it's just under 1/2" difference in height at the rear of the bike (12mm)
Shouldnt be that big of a difference, may have to fool with your gearing a little though
Andrew
  • neighbourdave
  • neighbourdave's Avatar
02 Mar 2015 09:09
#663173
Bridgestone is phazing out the Battlax BT45.
I went to order a set last week for my Z1-R.
1998 Concours
1978 Z1-R
1975 H2C
1974 H1E
1973 S2A
