Which tires do you use?
- TheDane
24 Feb 2015 14:46
Hi
I'm in the middle of finding new tires for my KZ550A1.
What i found until now is the Dunlop D404 100/90-19 for front and Dunlop D404 110/90-18 for rear.
I would actually like to go 90/90-19 front and 120/90-18 rear. But haven't really been able to find that for the rim sizes (1.85 front and 2.15 rear)
Anyways. What I would really like to know is what tires you are using and if you can recomend it.
Kawasaki
EngineKZ550A 1980
Frame KZ400J 1981
EngineKZ550A 1980
Frame KZ400J 1981
Re: Which tires do you use?
24 Feb 2015 15:05 - 25 Feb 2015 06:38
The rims on my KZ650-C1 are 1.85-19 front/ 2.15-18 rear. I run a 100/90 V 19 tire on the front and a 120/90 V 18 tire on the rear. I would not recommend going skinnier or fatter. Why would you want a 90/90-19 front ? :huh:
I have been using Pirelli Sport Demons for the last 6 years, and they work great in the sizes I mentioned. I would never put another Dunlop tire on my bike. I ran 4 different types of Dunlops and they all sucked. Others may have had better experience with them and/or with different model Dunlops that I had, but I found all the ones I used were too slippery. Ed
Attachment PirelliSportDemon.jpg not found
Last edit: 25 Feb 2015 06:38 by 650ed.
24 Feb 2015 16:31
Too small a front tire will tend to "wash out" in the turns and dirt. I ran Dunlop K 81's in the day. Were the best. Not now.
- bountyhunter
24 Feb 2015 19:11I currently run 100/90-19 front and 110/90-18 rear. The rear seems a shade skinnier than the stock which was 4.00-18 so next time I will probably go up to 120/90 rear.650ed wrote: The rims on my KZ650-C1 are 1.85-19 front/ 2.15-18 rear. I run a 100/90 V 19 tire on the front and a 120/90 V 18 tire on the rear. I would not recommend going skinnier or fatter.
24 Feb 2015 19:16
On mine the 120 on the rear is excellent. For years I has shoehorned a 130/90-18 on the rear rim, but I eventually discovered that because of the narrow rim the cross section of the tire was distorted and it didn't really work any better (maybe not as well) as the 120. Ed
24 Feb 2015 19:31
I'm also using 100/120 on those same size rims. Conti Go's are nice, and cheaper than many other similar tires.
www.americanmototire.com/catalog/index.php?cPath=33_108_871
- Nebr_Rex
24 Feb 2015 19:36
+1 on the Pirelli Sport Demons and Conti -Gos.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- RonKZ650
24 Feb 2015 20:10
The D404 is the worst tire made since 1900. Don't use that thing. There are many 3.25-19 tires available as well as 4.00-18. 100/90-19 for front can be swapped in place of the 3.25-19, but for the rear, the original tire was a 3.75-18 I believe, a 4.00-18 would be perfect. A 110/90-18 is a size that replaces, sure it does if you like a wimp looking tire in low profile. A 120/90-18 is too wide for a KZ550. Just my opinion, and I'll stick by it.
- 80B4
25 Feb 2015 06:50
I am using a set of Conti Go's on my 1980 B4 KZ1000. They are very good for a bias tire. My next set for a vintage bike will be Conti Classic Attacks, radial tires for classic bikes.
www.americanmototire.com/catalog/index.php?cPath=33_108_1084
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- Proxy
- 80% Human 20% Nuts/Bolts
25 Feb 2015 09:40
Bridgestones on my daily rider and Avons on my spirit bike.
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
25 Feb 2015 11:18 - 25 Feb 2015 11:19
Bridgestone Battlax BT-45. Good wet traction.
I got a TL set from motorcyclesuperstore a year or two ago for about $200 & they seem like good tires.
Last edit: 25 Feb 2015 11:19 by martin_csr.
- Grumpy Ole Artist
- Eschew Obfuscation!
25 Feb 2015 12:00
I Loved the Z-rated Metzlers on my turbo, soft sticky/replace every year...but...Gotta go with Avon Roadriders...Pretty darn sticky, lean pretty darn far over, (haven't scared me YET!) smooth transition through the lean, & while I have been able to break the back one loose on a wet road, you have to sort of "try" to do it...I will give them 2 thumbs up,(& the price ain't bad either!) I would buy another set...
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
