Sprocket locking tabs Necessary ?
  • kzz1king
  • kzz1king's Avatar Topic Author
22 Feb 2015 15:17
#662406
I am replacing the spoked rim on my Zee with a mag. The nuts on the sprocket carrier are round on the bottom so I don't think the thin metal locking piecesI bought will work. Are they needed? Just tighten them down good? Use loctite? Thanks.
Wayne
Home built KZ1000 turbo setup
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Sprocket locking tabs Necessary ?
22 Feb 2015 16:03
#662414
Nyloc locking nuts might be another way to do it for a low mileage well maintained bike, but the plates are there for a reason as that part gets a lot of vibration. IIRC The thread is metric fine or superfine pitch, not the easiest to source.
  • baldy110
  • baldy110's Avatar
22 Feb 2015 18:49
#662434
You don't need those locking tabs unless you are restoring the bike to original specs. In 35 years of working on bikes I have never seen a bolt come loose on the sprocket carrier, ever. Just torque them down to specs and your good. The OEM's stopped using those years ago.
  • kzz1king
22 Feb 2015 19:51
#662436
baldy110 wrote: You don't need those locking tabs unless you are restoring the bike to original specs. In 35 years of working on bikes I have never seen a bolt come loose on the sprocket carrier, ever. Just torque them down to specs and your good. The OEM's stopped using those years ago.
Want to buy some locking tabs? B) Thanks
  • 80B4
  • 80B4's Avatar
22 Feb 2015 20:47
#662439
The flat side of the nut goes towards the lock tab. If you have new lock tabs, use them.
1980B4 1000
1978 Z1R
1978 B3 750
  • Tyrell Corp
23 Feb 2015 09:48
#662479
I have, once on a puny z200, although I suspect it had been maintained by a chimp.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Feb 2015 12:54
#662499
I don't have any on mine and the guy on ebay wants $50 for a NOS one. Use lock washers if you're concerned.
23 Feb 2015 14:19
#662511
No eBay APP ID and/or Cert ID defined in Kunena configurationHere's 3 for $10.99 w/free shipping. Ed
  • kzz1king
23 Feb 2015 14:26 - 23 Feb 2015 14:27
#662512
80B4 wrote: The flat side of the nut goes towards the lock tab. If you have new lock tabs, use them.
Ummm, I knew about the flat part :laugh: Here is what the stock nuts look like.
Attachment images.jpg not found
Last edit: 23 Feb 2015 14:27 by kzz1king.
23 Feb 2015 15:03 - 23 Feb 2015 15:04
#662516
Interesting. The stock nuts on my KZ650-C1 do not have that round section. According to the parts diagrams (see 1974 Z1 diagram below) the 1974 Z1 uses the same part number (#42045-005) as the KZ650-C1. Is it possible someone swapped yours before you bought the bike? Below the diagram is a picture of the 42045-005 nuts. Ed
Attachment 00003a_2015-02-24-2.jpg not found
Attachment 00003c_2015-02-24.jpg not found
Last edit: 23 Feb 2015 15:04 by 650ed.
  • kzz1king
23 Feb 2015 17:24
#662524
I am putting a later model cast tubeless type rim on Ed. It is a 16 " drum brake. I dont know what year or model Kawi it is from. My Z! stock sprocket carrier looks like what you posted.
Wayne
