Rpm at 70mpr
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Rpm at 70mpr
31 Jan 2015 21:21
#660277
I've found myself looking for a sixth gear for years. Would be nice. I don't think there's enough room.
  • yorkieUK
  • yorkieUK's Avatar
Re: Rpm at 70mpr
21 Feb 2015 17:01
#662287
I'm running a KZ1000P-9 on stock rims. I changed my rear sprocket from 41t to 38t to reduce my revs at 70mph & improve my fuel economy (I now get 15-20 extra miles from a full tank). Front sprocket is standard 15t.
At 70mph I am at 4000 rpm. Before I changed the rear sprocket, it was 4300rpm at 70mph.
You can play around with your gear ratio's and rpm at: www.gearingcommander.com/
1982 GPZ1100 plunger chop
1990 KZ1000P-9 (ex San Diego P.D.)
  • yorkieUK
  • yorkieUK's Avatar
Re: Rpm at 70mpr
21 Feb 2015 17:06
#662290
I know what you mean. There's nothing better than opening up the throttle in 3rd gear to get past anything fast!
40mph to 90mph in two twitches of the sphincter!!! :woohoo:
  • Kwaker2000
  • Kwaker2000's Avatar
Re: Rpm at 70mpr
08 Mar 2015 16:05
#663768
im worried im going to bend the needle as my clock only goes to 80mph ,im wondering would another clock fit :sick:
  • koolaid_kid
  • koolaid_kid's Avatar
Re: Rpm at 70mpr
08 Mar 2015 18:18
#663777
Kwaker2000 wrote: im worried im going to bend the needle as my clock only goes to 80mph ,im wondering would another clock fit :sick:
Absolutely. Certainly. Perhaps. What bike is it, btw? That might help. :whistle:
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • zukdave
  • zukdave's Avatar
Re: Rpm at 70mpr
08 Mar 2015 18:49 - 08 Mar 2015 18:55
#663781
I've rode my 80 mph speedo beside my buddy's ZRX at
over 130 mph and it didn't get mad.
The needle will keep going around and if you
get it all the way back to zero your F'in flyin.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 08 Mar 2015 18:55 by zukdave.
