Frame bracing?'s
- Mk.2
Frame bracing?'s
29 Dec 2014 16:14
I'd like to brace up my A1 frame(MIG) what type and thickness of tubing have you used and what's the wall thickness of the frame itself? I would imagine it varies depending on the specific area.
I was wondering if some mild steel .030 wall tube would be adequate??
Matt
KZ1000A1--current project
KZ1000A3A
Phoenix
KZ1000A3A
Phoenix
Re: Frame bracing?'s
29 Dec 2014 16:37 - 29 Dec 2014 16:43
.030 tubing should be fine. Use the largest diameter you can fit into the area you are trying to brace. Stiffness is greatly affected by diameter, far more so than thickness.
Last edit: 29 Dec 2014 16:43 by Nessism.
- Mk.2
29 Dec 2014 16:50
you sir are the man.
thank you
thank you
Matt
KZ1000A3A
Phoenix
KZ1000A3A
Phoenix
- StreetfighterKz
Re: Re:Frame bracing?'s
29 Dec 2014 17:18
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- 80B4
29 Dec 2014 21:12
McMaster.com has the 4130 tube you need, if you order before 5 PM you will get it next day.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
30 Dec 2014 06:18 - 30 Dec 2014 06:21
in the kits i have made i have used 1" o.d. x .065 wall chrome moly or 1" x .120 wall dom for the tubing,(depending on tig or mig.)
and used .080 to .120 thick hot rolled for the plate sections.
seems most of the frame tubes run between .080 and .120 wall in my experience.
hth,
the link streetfighter gave does have a ton of info.
hth,
Last edit: 30 Dec 2014 06:21 by 531blackbanshee.
The following user(s) said Thank You: Mk.2
