Standard Vs LTD?
- ed spangler
- Tennessee Z
Standard Vs LTD?
19 Dec 2014 11:28
I may have asked this before...if so, my apologies! I guess its an old age thing. Anyway, is there a way to determine from engine or chassis number....If a bike ( 1975 Z 900 ) was originally an LTD or a Standard Z model?
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
- Kapahulu
Re: Standard Vs LTD?
19 Dec 2014 11:58
I think they started making LTD's in 1976.
Here's a page showing the '75 VIN range: www.zedder.com/Info/75%20Z1-B%20900.htm
2strokeworld.com
2strokeworld.com
The following user(s) said Thank You: bluezbike
- bluezbike
19 Dec 2014 11:59
I'm pretty sure that the first time a LTD was introduced was in 76 so your 75 should be a standard model
79 KZ 1000 LTD
- ed spangler
- Tennessee Z
19 Dec 2014 13:15
Thanks Kapahulu and Bluezbike
My Chassis number is Z1F503xx Engine is Z1E0526X......hmmmmm..... Engine number seems much lower than chassis?!..Guess I am gonna have to look at bike and verify this, these numbers were from the Title
Does that help?
Does that help?
- Mcdroid
- Gone Kwackers
19 Dec 2014 13:23
Seasons Greetings ED...check your title against the actual VIN numbers...it might be a typo...but if the difference is real, then perhaps either motor cases or frame has been replaced (depends how Tennessee registers motorcycles).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- floivanus
19 Dec 2014 14:04
The 76-80 ltd frame vins start with kz900B for the 900 or kzT00B for the 1000's
They were actually a limited edition for 76, after that they seemingly sold better than the standards, yet they seem like a downgrade, smaller gas tank and all.
Past; 78 kz1000, 83 kz550
Andrew
Andrew
The following user(s) said Thank You: PLUMMEN
- !Seymore
- Ride on...
19 Dec 2014 15:27 - 19 Dec 2014 15:27ed spangler wrote: Thanks Kapahulu and Bluezbike
I can tell you that none of the numbers, bike/engine, match on my bikes... and they all were stock orig parts. Maybe others can confirm, but it's quite rare to have EXACTLY matching numbers...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Last edit: 19 Dec 2014 15:27 by !Seymore.
- RonKZ650
19 Dec 2014 15:34 - 19 Dec 2014 15:44
Numbers don't match normally, but are usually close. I'd consider variances of 100 the max to be the original engine/frame. Being off by thousands guarantees somethings been replaced. The 5 in the first vin indicates a USA built unit, the 0 in the second indicates a Japan built unit. I don't believe they ever matched a USA frame with a Japanese engine, but could be mistaken. I think 1976 began the USA builds, so without knowing anything for sure I would guess a 1976 KZ900A, with an earlier year engine installed.
Last edit: 19 Dec 2014 15:44 by RonKZ650.
19 Dec 2014 17:29
The 75 was a Z1b model. The LTD didn't come out until 76 I believe.
- ed spangler
- Tennessee Z
20 Dec 2014 07:02Mcdroid wrote: Seasons Greetings ED...check your title against the actual VIN numbers...it might be a typo...but if the difference is real, then perhaps either motor cases or frame has been replaced (depends how Tennessee registers motorcycles).
Thanks Michael!
Seasons greetings to you and the family as well!
Yes, I need to compare numbers on title with whats on bike.
Regards
- bluezbike
20 Dec 2014 10:55 - 20 Dec 2014 10:56
According to K Parts catalog I have 1975 Z1's were as follows:
Frames - Z1F - 047500 - 085700
Engines - Z1E - 046500 - 086000
So it looks like your motor is a 75 but the frame does not fit, I have heard that up to about 200 difference in numbers was OK as they produced both replacement frames and motors for those that needed them. I suspect as has been mentioned there is a typo of some sort.
Hth
Hth
79 KZ 1000 LTD
Last edit: 20 Dec 2014 10:56 by bluezbike.
