530 sprockets for 1985 GPZ750?
  • taylee
  • taylee's Avatar Topic Author
01 Dec 2014 14:19
#655090
I would like to go to 530 sprockets but have heard conflicting tales. Some say I need special offset sprockets. Others have said I don't. I don't see why slightly changing the width of the chain will necessisate a new offset. Can someone with experience help me out?
[IMG
1985 GPZ750 (non-turbo)
  • pete greek1
  • pete greek1's Avatar
Re: 530 sprockets for 1985 GPZ750?
01 Dec 2014 14:32
#655092
No need to offset, unless you're putting a wider swingarm & rear rim
  • DoctoRot
  • DoctoRot's Avatar
01 Dec 2014 14:58 - 01 Dec 2014 14:59
#655094
You shouldn't need to offset, however if the stock sprocket has a boss on it, and your 530 sprocket does not, you will need to get some spacers to get it correctly positioned. I had to do it on my kZ1000 when i converted. Im not familiar with your bike so i don't know if that would be the case. Your best bet is to pull the sprockets and see if there are a bosses on either. There is some very helpful info on 630/530 conversions and sprocket spacing over at z1 enterprises.
www.z1enterprises.com/Chain630To530.aspx
Last edit: 01 Dec 2014 14:59 by DoctoRot.
The following user(s) said Thank You: taylee
